Nimrod
Same place our 04S leaked.OK, so here's the result of last nights test...
All the black taped seams were good. No leaks detected except one single droplet near the bottom left of the front arch window, (see picture below)...
However, disappointingly, but as expected, the 2 front long vertical corner seams, (which are un-taped), leaked quite badly, (again see picture)...
It was approx 03:30 when I took this picture. The rain was moderate and constant with wind blowing at the front.
I have video too, but no idea how to upload it!?
Then at approx 04:30 the rain became quite heavy and the front bottom of the bellows, (where it attaches to the van), was leaking quite badly. I put down a load of kitchen towel, which did a good job of mopping it up, but it was a constant stream into the van at this point.
Again I have video, but can't seem to get it to upload. Apparently you can't upload MP4??
Anyway, overall I'd say that these 05S bellows are better than the 04S, as more seams are taped, but I just can't understand why they haven't taped the front and rear corner vertical seams too? And as such these continue to leak!
Also, I'm concerned with the bottom leaking in the way it did, but at this point the rain was really very heavy, so perhaps the outside front gutter was getting full and it was overflowing back into the van through the seal??
I have a call with Rhiannon from VWEO on Tuesday, so I'll update her with the findings and send her the pictures and videos.
Hopefully she will be able to pass the detailed information I have, back to the technical team, so they can get to work on the 06S.
Thanks for posting the photo. We haven't had any rain yet this weekend but if it starts I will put the roof up and check the same seams.OK, so here's the result of last nights test...
Thanks for the tipTo show videos upload to YouTube and then provide a link.
Thanks for the tip
I've never uploaded anything to YT before, so unless anyone specifically wants to see the vid's then I'll happily remain a YT virgin!!!
I'm sure you've all seen a leaky bellows before by now anyway!!!
Further to above, First real rain experience since Install, we are up in Ballater just now, it poured down in buckets all night and our new 04S A Bellows did not leak a drop I am relieved to say. Will to continue to monitor, but feeling confident we have a fixI asked the question to which they confirmed it had been tested but didn't provide details of how they test.
I put the roof up a 15:00 as it started to rain, still raining now, just checked & currently bone dry. It is only light rain but continuous, it looks as though it will be raining here for most of the night so plan to keep an eye on it. Will inform as things develop, good or bad.
From my Handbook. Yours might be different.Real world test of my 04S last night down on Dartmoor with >12 hours of constant properly heavy rain.
- previously they have not leaked albeit compared to last night, have faced only moderate rain
- having seen the forecast I thought I am going to finally spray the seams with Aquatex. Two coats on all seams externally and a bit of a half hearted effort internally
- went to bed after 8 hours of non stop heavy stuff - not a drop had entered at this stage. Wind was driving it at front corner.
- woke this morning to a few drips having entered the lower front window seam. 6 distinct trails down the canvas. But only enough to dampen a single sheet of kitchen towel, not soak it.
- all other seams 100% dry
Is this a success ? It feels like it after what’s gone before with the 03S I had in similarly heavy rain, albeit shorter duration, and where we got flooded. Bit frustrated to find a few drips this morning, with it having held out so well for hours, but thinking back to my camping days in that sort of rain there was always some sort of minor ingress.
Did the Aquatex make a difference, will never know, but I suspect it must have and am glad I did. Will give that front seam another coating though. As others have said it is invisible so for £10 it’s well worth it.
I hadn’t appreciated that and having read this thread not sure everyone does? e.g. using hosepipes to test would mimic a storm?From my Handbook. Yours might be different.
• Close the pop-up roof during storms with driving rain and wind gusts. Otherwise the bel- lows could leak despite their specially treated fabric. <J
Use an external cover or wrap.I hadn’t appreciated that and having read this thread not sure everyone does? e.g. using hosepipes to test would mimic a storm?
It raises another issue though, what to do if you have 4 people on board and a storm arrives?
Def 03SNow I am trying to identify what canvas it is. It’s dark grey on the outside and cream on the inside.
Along with the semi circular window seam, that horizontal seam is one of the worst affected. When did you get the 04S installed? At this point only 05S should be used.constant rain and my replacement bellows leak on the front seam. 2024 Cali Ocean. 04s dated 21/12/23. Anyone else had leaks from there?
Internally is just as important as external, that way the thread is getting a waterproof coating both sides and it will probably wick into the centre of the thread.Real world test of my 04S last night down on Dartmoor with >12 hours of constant properly heavy rain.
Yes, because some 04S bellows seem to be OK.I am about to purchase a new stock cali from a dealer which is 300miles away. The bellow is 04S.
They cannot replace it without seeing a fault, do I just bite the bullet as they all seem to be 04s ?
I assume a local dealer in kent will undertake the warranty ?
I'd say no.I am about to purchase a new stock cali from a dealer which is 300miles away. The bellow is 04S.
I suppose, having a 05S just makes it more usable without all the worry and you can actually use it while a real fix is in the making. No need for a wrap etc. It's just less hassle.I see what you are saying but if the 05s still have issues then it isnt a fix, so potentially would still need replacing and potenially lose out on a vehicle that is good spec.
I assume the any local VW service centres will have to do the work regardless of where it was purchased?
I picked up my new van yesterday and the dealer said the accepted hosepipe test they use is a fine mist spray for 30 minsThe Cali dealer I bought the van from is fully across the problem but they are 250 miles away. As soon as I spoke to them they told me yes it’s a known problem, they have the fix but would need to go through the warranty process. My local dealers, only 60 miles away, know the problem but have only replaced a few canvases and want to to the test first. The original dealer service guy is being way more helpful. He would like video and will talk to VW and get the warranty sorted so I only have the one visit to do. Could be a result ;=)
So my question to you folk is - what is the test? A simple hose on the front window?
Is a leaking roof a good spec for a £70k campervan?I see what you are saying but if the 05s still have issues then it isnt a fix, so potentially would still need replacing and potenially lose out on a vehicle that is good spec.
