stationmaster
- Messages
- 536
...fine mist spray? 30 minutes?I picked up my new van yesterday and the dealer said the accepted hosepipe test they use is a fine mist spray for 30 mins
Totally unacceptable.
Completelz agree. Bellows have to be saturated as Step 1...fine mist spray? 30 minutes?
If you've highlighted the issue before the warranty runs out, I think you're ok. As I see it, fundamentally as long as you identify the issue while in warranty and can confirm it hasn't been resolved, you should still be covered for that issue, irrespective of if the delay is because of the dealer or a fix from VW themselves. It would be different if you are 6 months post warranty expiry and announce you've got a leak.What happens when vehicles fall outside the warranty period due to the procrastination of vw to find a solution?
Will they honour the fact the problem arose during warranty and apply whatever solution they come up with, no quibble?
I get you now. Thanks for explainingI would suggest that if any of us stood in a mist spray for a full 30 mins we would be saturated and I think that’s the point the dealer said.. saturated but not forced water ie pressure.
It was replaced in April. I collected my Cali first week of MarchAlong with the semi circular window seam, that horizontal seam is one of the worst affected. When did you get the 04S installed? At this point only 05S should be used.
So I’ve got same O5S manufacture date as your label but got the A sticker in addition …you just wonder what significance that is?
04s installed in April, van booked in so will see what they say!Along with the semi circular window seam, that horizontal seam is one of the worst affected. When did you get the 04S installed? At this point only 05S should be used.
Interesting. Mines dated 10-04-24 without an 'A' sticker..Here’s the label….DOM which I think is the same as Nimrod but difference is mine has an A sticker too?
I tried zooming in but your 0 of the 10 distorted to what looked like an 8, hence thinking it was the same
Let's just hope the 'A' sticker is reserved for the ones that don't leak, irrespective of DOMI tried zooming in but your 0 of the 10 distorted to what looked like an 8, hence thinking it was the same
Hope you had a nice holiday in Cornwall?…was their any West Country rain and if so how did your bellows fair?Took delivery of our new Cali yesterday which is fitted with O5S A bellows. The fabric is single skin, dark grey on the outside, coated with something silver/grey on the inside, it looks the business.
The seams generally show no sign of pin holes. The whole thing looks very well made.
BUT !
Because the complete bellows are stretched very taut, the two front corners are showing signs of stress at the base. Light showing through the fabric and a row of holes being evident along the bottom seam.
Off to test them in Cornwall next week.
Are they suggesting replace with a luckier set or take on board your comments regarding the lack of black tape on the four corner seams?Let's just hope the 'A' sticker is reserved for the ones that don't leak, irrespective of DOM
I spoke with VWEO today and they informed me that to date I'm the first leaking 05S. So fingers cross for everyone else.
To be fair, I think at this stage they're just collecting data.Are they suggesting replace with a luckier set or take on board your comments regarding the lack of black tape on the four corner seams?
So will you just go down the Aquatex route to prevent the dribbles?To be fair, I think at this stage they're just collecting data.
Undecided. I guess I'm also collecting dataSo will you just go down the Aquatex route to prevent the dribbles?
Man , this “you are the only one” recurring theme from VWEO whichever bellows we are talking about. 03 04 04 post nov 23. Same story. Good luck out there.Let's just hope the 'A' sticker is reserved for the ones that don't leak, irrespective of DOM
Some leak, some don't, however, if it they eventually leak, then they will be replaced under warrantyI am about to purchase a new stock cali from a dealer which is 300miles away. The bellow is 04S.
They cannot replace it without seeing a fault, do I just bite the bullet as they all seem to be 04s ?
I assume a local dealer in kent will undertake the warranty ?
In a nutshell, irrespective of what version they are.Some leak, some don't, however, if it they eventually leak, then they will be replaced under warranty
