RockinNRollin
Where to next?
Fabsil is not odourless. With my roof up or down, there is no new odour in my van. I don’t think there’s been any superficial fabric treatment
The second to last two letters are the variation number for VW parts. So this is the 8th version of variant C. Rest stays the same.I was told that the part number for the latest has NR at the end. There’s a photo of the part number fitted to mine in one of my early posts. No idea how that compares to others.
V7LA 875 059 C8 NR
I suspect it is. This and looser fitting bellows so the stitching holes aren’t stretched open. This may provide an adequate enough solution and is possibly fit for purpose now, but I wouldn’t be surprised if they’re still not as water tight as the previous generation bellows.I really hope this is not the solution VW are using… Has the part number now changed? If not, what has I wonder.
So it leaks along the seam at the bottom of the window only?It may not be over. These bellows leak and another owner with bellows from the October manufacture are leaking along the lower seam.
ApparentlySo it leaks along the seam at the bottom of the window only?
Lower seam to me sounds like the lower seam at the base of the bellows where it meets the black rubber. Mine leaked there too.So it leaks along the seam at the bottom of the window only?
Yes, I misread Kayleigh's question. Lower seam where it attaches to the roof is what I meant.Lower seam to me sounds like the lower seam at the base of the bellows where it meets the black rubber. Mine leaked there too.
OK. Yes mine has some significant stitching holes at the corners along that seam. They were exacerbated by the taut fabric as well.Yes, I misread Kayleigh's question. Lower seam where it attaches to the roof is what I meant.
On my original bellows this was the main area of leaksge along the front edge, but on my replacement bellows these holes were nowhere near as taut along the straight edges, but still taut and leaky in the corners.OK. Yes mine has some significant stitching holes at the corners along that seam. They were exacerbated by the taut fabric as well.
It’s definitely not an installation issue on that lower seam if it leaks the same way mine did. It’s another stitched seam that gets stretched open under tension. 100% a manufacture/design issue.Mine were dated end of September test/manufacture, but that doesn't mean to say there aren't two different versions of bellows in circulation from the same time period. Depending on where exactly it leaks on the join, it could be install error as if that lower edge isn't sealed in properly then it may still leak with perfect bellows.
Looks much better in the middle but not so good in the corners.Unlike the front window it’s really easy to see if you’ll have an issue with the lower seam or not. Here are some photos of my original bellows vs replacement bellows. The originals have pin holes everywhere on this seam and leaked liked a sieve. The replacement had far fewer pin holes and was much better, but still leaked where you can see daylight shining through. Just put your roof up and look for these holes, then look carefully in this area when you hose/rain test it.
I found the lower seam also seems to suffer leakage from water landing directly here on the outside rather than seeping into the fabric as these holes go directly through to the outside.
Yes the replacement was a much looser fit and didn’t have the same issue in the middle. The corners still leaked badly though, exactly as the pinholes suggest. It did also leak through the front window and the vertical seams on the front corners.Looks much better in the middle but not so good in the corners.
Did it leak from any other seams/zips?
When did you have your bellows (most recent ones if more than one!) replaced?Yes the replacement was a much looser fit and didn’t have the same issue in the middle. The corners still leaked badly though, exactly as the pinholes suggest. It did also leak through the front window and the vertical seams on the front corners.
Mine were replaced in late July. It was a very early replacement and don’t think there was a design change then. Part number was exactly the same. The new set were definitely better than the original set though. But the issue of the leaking at the lower seam sounds like it could still potentially be a problem on recent replacements that are the most up to date version. I hope not but this is perhaps an area to check carefully for anyone with the newest replacements.When did you have your bellows (most recent ones if more than one!) replaced?
My sources were 2 posters on Calibord, one with late Sept and the other early Oct bellows production dates.Perhaps I've missed the post, but what's the source of this latest leaky bellows? I don't recall seeing anyone who is a member on here stating it, just @Corradobrit mentioning it had occurred? Given we seem to have literally in the last week seen the transition from naff > good bellows, timing could be quite critical here (irrespective of the date stamped on the bellows as I think there was less than a week in it on my replacements, yet one leaks and the other didn't during testing). My guess is there is an overlap in the dates - not sure how it happens in real terms, but that does support the theory.
Do you still have your Cali or has it gone back now?So we have two positive stories from Rocknrollin and Betsycalifornia.
Has no-one else had replacements in the last 7 days??
