aliceh92
I’ve got a major leak in the roof and water pouring in :-( any ideas? Or anyone had this happen? Roof is closed on the screen. 2006 reg cali.
That looks serious.
Possibly. It has let in a huge amount of water but admittedly I hadn’t checked the drain holes until now. Although the previous owner had it repaired under warranty but not sure what it was, while doing warranty work there was a hammer left in the pop top and then they had to fix the roof but it all seemed fine and in storms previously hasn’t done this. I’m hopeful it’s a drainpipe issueThat looks serious.
Do you know if the roof has ever had the 'repair' done to it?
Posting a few pictures of the roof might help,Possibly. It has let in a huge amount of water but admittedly I hadn’t checked the drain holes until now. Although the previous owner had it repaired under warranty but not sure what it was, while doing warranty work there was a hammer left in the pop top and then they had to fix the roof but it all seemed fine and in storms previously hasn’t done this. I’m hopeful it’s a drainpipe issue
Has it been standing or driven or parked? If it has had the front cap (the panel above the windscreen) replaced as part of the roof warranty repair.Possibly. It has let in a huge amount of water but admittedly I hadn’t checked the drain holes until now. Although the previous owner had it repaired under warranty but not sure what it was, while doing warranty work there was a hammer left in the pop top and then they had to fix the roof but it all seemed fine and in storms previously hasn’t done this. I’m hopeful it’s a drainpipe issue
No way should you use a high pressure line. Very good chance of blowing the drain pipe and connector off.High pressure air pipe if you have access.
be careful pushing anything down the pipe apparently you can dislodge the drain pipe.
good luck
Suck don’t blow!No way should you use a high pressure line. Very good chance of blowing the drain pipe and connector off.
Did you get this fixed, what was the remedy? ThanksPossibly. It has let in a huge amount of water but admittedly I hadn’t checked the drain holes until now. Although the previous owner had it repaired under warranty but not sure what it was, while doing warranty work there was a hammer left in the pop top and then they had to fix the roof but it all seemed fine and in storms previously hasn’t done this. I’m hopeful it’s a drainpipe issue
