Yes. But I soldiered mine directly into the rear reading light. There is also a space by the light to store the little transformer / dimmer control box that comes with the Khyam vanlite kit (which is wired to suit a 12v cigarette plug)
Includes, remote control fob and connection box, switched and fused plug socket and wiring.LED lighting to fit under your vehicle sun canopy box or awning rail and fixes simply into place with 3m tape. The power plug is fused, switchable and illuminated when on. Alternatively attach to an...
www.khyam.co.uk
The difficult bit is routing the wire into the vehicle. What's shown isn't possible unless you want to notch the seam on the tailgate. Which I didn't want to do. Mine is routed under the tailgate seal (on the outside of the seam) and pops into the RH light cluster and then routed back in behind the RH rear panel (The rear HVAC unit is located here) and up the rear quarter. This is the difficult bit.
