Level site
Kencouceirovwc
Kencouceirovwc
Kenco
Cornwall
T5 SE 180
Has anyone found a gauge that tells you if your cali is level on a site. I had a Shogun many years ago that had I think it was called a inclinometer. Is there something I can get to put on the dashboard
Spirit level/inclinometer App?
The iPhone has a great one built in.
pour a cup of tea put on work top and check by eye
We just put a bit of water into the sink. Easy to see if level, or if not, in which direction the water flows to show which corner or side is low.
Thankfully our 6.1 has it built in but as others say, all modern phones have a spirit level built in that works a treat. Just place it on the floor flat on a cup, else the camera bump will move you off level.
Sliding door give a good indication of level ground. Open half way, if it stays put then at least level in one direction.
If you have an iPhone you can use the "measure" app, installed on your phone by default.
I use a very simple water level left by the previous owner when he sold the car. We only measure this when it's flat :rolleyes:, but when the terrain is severely sloping then there's nothing left but a few days of slightly inclined living.
Plastic milk bottle half full of water placed on its flat side
I use the App Camperset it tells you exactly what to add on each weel, and also shows it on your iWatch. So I put the iPhone on the floor and look on my iWatch as I move up on the levellers.
We have a marble that we put on the sink cover. Works a treat!
