Perfectos
It sounds like the coding has not been done / done correctly.
What I don’t understand fully is your comment regarding PFJ ; coding being optional, the Westy tow bar requires coding to tell the vehicles ECU that a towbar is present so the towing electrics will function properly, which I suspect is the source of your problems Or the wiring has been installed incorrectly.
Westfalia sell / provide a device to allow coding to be carried out, I wonder if this is an option for home install ?
good luck getting it sorted, report back to help others
vwcaliforniaclub.com
T6.1 Towbar Fitting (due to factory delays!)
Due to factory delays on tow bars thinking of fitting one myself as it will probably push our build date to after august(currently it’s June!) I’m an engineer and have fitted bars loads of times just not on a Cali So has anyone fitted a towbar to a T6.1 yet and do you have to remove the kitchen...
