CaliBear
Me too! It is useful as a pre wash though. I can recommend Bilt Hamber Autofoam. It's better value than Meguires (probably a bit better product too). If you buy direct from Bilt Hamber it's about £17 for five litres rather than around £20 for less than one litre. Once you follow the mixing ratio guide and measure the discharge rate from your snow foam lance or detergent tank, it's surprising how little product you use. Also helps to mix the snow foam with hot water in the lance bottle/detergent tank.To be honest I’m not convinced that snow foam really does much, which is why I only bought the cheap Karcher. I’ve not tried any of the premium foams, so maybe I need to stump up and give Meguires a go.
