I think there is still much confusion owing to the fact that
VW green heat insulating glass and
VW green heat insulating privacy glass are sometimes (quite often) acknowledged by owners under the same term of
Standard VW tint.
Everything below is simply based on what I have read on this forum and for sure there are still posts that contradict what I have surmised but here goes..
I believe that asides the extra level of tint in the later of the two types, the most telling difference is that the privacy glass has the blacked out section behind the wardrobe and the other doesn't. I don't know that for sure though.
Therefore, if you
don't have VW green heat insulting privacy glass there would be a benefit in removing the window to get it tinted the same as the rest. Where as if you have VW green heat insulating privacy glass there is likely to be no need to remove the window. So which ever
@mario+jill had they preferred to remove it even if it was blacked out.
Now who wants to throw in further complications of double glazing and laminated glass?
OK I will
Double glazed units (standard on the ocean and an option on the beach) and singled glazed units definitely have a different effect regarding reflections. this is evident on my Ocean with some double glazed VW green heat insulating privacy glass. The difference is minimal but it's there at some angles in some lighting conditions between the single glazed and double glazed areas.
In this case, I'm not sure if this difference will noticeably increase if you add after market tints to all windows but I'm also sure it will not reduce the original difference all of the time. However it will look darker and uniform in some circumstances so likely to be an overall improvement.
From the pictures I have seen I'm now leaning towards VW green heat insulating glass (not privacy) with double glazed areas being the least capable of getting a uniform finish when after market tints are applied thanks to the seperate challenges of double glazing and lack of blacked out panel by the wardrobe. If this is your set up the limo tint and window removal (a la mario+jill) seems a good bet.
Single glazed beaches should be the easiest to get uniform.
As for laminated glass, the same thing applies...single glazed? good match all round. Double glazed? same issues but likely to vary in any mismatch.
Clearly some Oceans have had really good results and others have a more noticeable mismatch so until we can categorically iron out any inaccurate descriptions you have to work it out yourselves but I hope my theory goes someway towards understanding your chances.
I think a medium tint on top of VW green heat insulating privacy glass has had good results from pictures on the threads.
