Roof bars and solar panel
I
icic
UK
I have installed on of Rogers excellent solar panels. I was wondering about roof bars. Occasionally I would like the options of fitting roof bars, mainly to carry a 8 foot surf board. I would rather not keep taking all the bolts off the solar panel every time I mount the bars and also know that Roof bar shadow effect the panels efficiency. Just wondered if any one had any solutions they have found works with this set up
I
icic
UK
The solar panel I have mounts into the roof groves where the bars go
Mike Currie
Mike Currie
Edinburgh
T6 Beach 150
I have had roof bars and a single solar panel for 2.5 years and it has been fine. Sun would have to be very low in the sky to cast a shadow on the panel.
Alan Andrews
Alan Andrews
Staffordshire
I think that advice is to go for 2 panels in order to compensate for low sun and/or obscured sun hitting the panels due to the roof bars and any load being carried.
I
icic
UK
But does that mean I have to keep the roof bars on all the time as they need to go past the bolts securing the panels, if you see what I mean. Or can you mount the bars for easy removal. Would like to take them off when not using them for keeping under the 2 m barriers
Alan Andrews
Alan Andrews
Staffordshire
Interesting dilemma. I guess that you can see if the bars work for you if you position the solar panels central on the roof. Allowing the each bar to slide in/out at very front and very rear of track.
Paul Cardiff
Paul Cardiff
Cardiff
Motorhome
I know mine is a marcopolo but similar concept. See picture, I keep the base of the Thule fitting kit to the front end of the roof, doesn’t rattle around and allows you to for the roof bars when you require them. Avoids taking the solar panel off when you need the roof bars. You can move them into position when you want them, they slide freely. You can see my solar panels fitted at the rear of the van.18EDB3C5-9D30-4A9E-A9AD-41CB5D935817.jpeg
Ch1pbutty
Ch1pbutty
Burgess Hill
T5 Beach
Get the self adhesive solar panels that attach directly to the roof. Then you can just fit roof bars as & when required.
Amarillo
Amarillo
Tom
Royal Borough of Greenwich
T6 Beach 150
I have two of Roger's panels and install roof bars and a tandem carrier whenever we need to transport our tandem or our tandem triplet.
One roof bar goes in front of the solar panels, the other bar goes behind them. Removing the bars and tandem carrier is a fairly simple and quick one person job, and I do it without detaching the tandem carrier from the bars.
soulstyledevon
soulstyledevon
https://www.instagram.com/kennycalifornia
Cali now sold
Amarillo, you must get some odd looks with the Tandem on top of the Cali... :thumb
Amarillo
Amarillo
Tom
T6 Beach 150
We get odd looks just riding the triplet. I have now dusted off my flatbed bicycle trailer, and attached the hitch to the triplet. Once lockdown ends I can go cycle touring with the two boys.
Here's the trailer and box attached to my Brompton.
I
icic
UK
That makes sense nd bar at each end .. thank everyone
OllieCollieCali
Californication69
Californication69
GrumpyGranddad
5K
markanichols
markanichols
Trollhunter
Roger Donoghue
Roger Donoghue
JohnGuppy
9K
Sean Gardiner
Sean Gardiner
