AndyWT
You have hit the nail exactly on the headOk so I’m firmly on the side of “no point”
I can manage four days with fridge (ambient depending obvs)
I couldn’t find any cold hard facts in this post about it’s capability.
let’s assume I have discharged my leisure battery to less than the required level to run the fridge.
Assume average UK weather and for fun, let’s assume I’ve been pitched by a CCC Hi viz muppet , so no choice on orientation.
Given that to charge a battery you need more than 12v etc.......
Will I be able to plug in the solar and carry on as before. ?
“Will I be able to plug in the solar and carry on as before. ?”
I’m pro Solar but! No one can answer that, there is no standard solar setup, there is no standard weather, there is no standard power consumption.
How long will you be without shore power? A weekend worrier can usually survive the until home.
Let’s look at the variables,
Panels 100-200W ? flexible or rigid
Voltage 12 or 24V nominal, actually 18 or 36V at full sun
Controller PWM basically a variable period switch, MPPT works like a variable Volt/Amp inverter and is required for 24V panels or 2x 12V in series
Size of cables ideally/hopefully min 6mm sq, length not an issue on a van.
Panels horizontal
Panels on raised pop-top, assuming it’s parked nose North
Shaded panels
Weather?
And unless you have a battery to battery charger an alternator cannot fully charge a battery, whereas solar can especially with a MPPT controller.
It will be a very optimistic person to expect everything to work perfectly in all situations.
My setup and why. We live part time in the van, more so as the rug rags have gone off to Uni, we have no power at the van parking although it’s a big garage in the yard near the house, we only go to campsites when the boss wants a shower.
2x 12V panels in series, flexible keep it under 2m
MPPT controller
180 Ah sealed lead acid battery
Yes we live in Italy, it’s not always sunny near the alps... but under clouds we still get 1-2 amp charge for a few hours.
We only use 12V, an inverter is a good way to kill a battery.
Why a lead acid battery? There are batteries and there’s batteries as in all things, I don’t consider the cost of AGM or GEL battery is justified, we have a Bosch T5 battery a high quality truck battery designed for abuse and high cycle use ie tail-lifts, only discharge down to 12.4V and it will last a very long time.
If you have late T4 Cali only a stupid long truck size battery fits a 140 Ah, Bosch is the only supplier I have found who can supply 180 Ah of same dimensions.
I didn’t mention cost, this is what I need... can be low or high cost, Victron seem popular here but costly, I will look at Lithium at some stage as it’s double the power density ie I can get double the Ah into the same space or same Ah into half the space, I’m aware of lithium limitation as I already run a number of things off lithium.
This is not going to convince anyone either way but!.....
