marchugo
- Messages
- 475
Part 1
Hello Calinistas,
Yesterday we had a meet-up at our Dutch California dealer Campercentrum Amersfoort. An astonishing two hunderd Cali owners showed up. We were packed like herrings in a tin.
Owner Rob Marshall did a very informative three hour stand up one man show, whith lots of information about T5/T6 technical aspects. We had a good laugh, as he was of course trying to sell us the articles of his shop. At the end almost everybody went home with two or three products. Almost like a tupperware party.
Anyway, some of his tips and hints may be of interest to others here on the forum, so I try to recapitulate some of the stuff here (also for my own aging brains...)
Marc.
Pop top roof:
– Sagging of the roof is normal if you camp somewhere for three days. Going down more than ten centimeters in an hour is not normal. Temporarily solution: move the pop top roof down and up, and you’re sorted for the day. Visit the dealer soon, maybe the oil cylinders that keep the bellows up are damaged or leaking.
– After removing the keys from the ignition, a sagging roof pumps itself up again automatically within twelve hours. Of course this happens preferably when you have just fallen asleep.
-The upper bed under the pop top is a safe place during thunderstorms (cage of Faraday). Sleeping upstairs or downstairs with an open roof is equally safe.
BUT: first thing to do when lightning is approaching is to remove the 230 V cable from the hook up outlet/inlet of your van. The lightning is attracted by copper cable.
– Malfunction of the pop top can be solved many times by resetting the camper unit (the computer above your head at the ceiling downstairs), by pushing the reset button (the button just under the scroll knob) for at least 15 second, WITH THE MOTOR RUNNING. This solves eight out of ten problems with the roof.
– Exploding cylinders were a regular event in Calis until 2008. Reason: VW had economized on the quality of the cylinders. In stead of double rolled steel (that is strong enough for 190 bar pressure), they used single rolled steel with a max of 150 bar.
To be sure, you can stick a sun protection alu foil on the black plastic casing that surrounds the cylinders (these casings are under the closed roof in the middel of the left and right gutters).
– Always open the roof with the motor running. This avoids differences in voltage between the motor batterie and the leisure batteries. Voltage differences can provoke malfunctoins in the electrical system, in case the motor batterie is almost empty.
Next: The motor
Hello Calinistas,
Marc.
Pop top roof:
Next: The motor
