panadero
Part 4
Theft
All T5 vans are vulnarable to theft by manipulating the OBD computer port under the dashboard. With smart software thieves connect to these ports and bypass the immobilizer and just drive away in minutes. In the Netherlands some camper insurance companies demand the installation of a OBD lock (like the Bearlock for the gears). This means another key again on your key bunch...
The electrical connector of the towbar is just as vulnarable to this OBD-manipulation. No solution yet.
The Bearlock is also vulnarable to thieves using an angle grinder, though this takes a lot of time and makes quiet some noise.
Just got this OBD lock installed, here's a picture.
Beside this they installed some kind of small steel plate over the upper part of the DSG gearbox (under the hood).Thieves did pull off the cable from it and put the box manually in D (to bypass the gearbox-lock at the dashboard). Not possible anymore....
