Biffarino
- Messages
- 4
Hello and sorry for another thread about awning rattles. I have used the search function but couldn't see anything that pointed towards what I suspect might be the problem.
I wondered if anyone had play in the front of their roller tube? The front end of mine has vertical movement but the rear end with the gear assembly has nothing at all.
So far I have swapped the rubber pads for the newer clips, put felt pads around the leg clip, used countless 3M rubber dots, stretched the springs, and used the charity wrist bands on either end of the outside casing. The next thing to try will be setting it on fire.
I'm pretty sure it is the awning. I asked my wife to tap the casing while I was sat inside and the noise sounded like it does on the road. Basically like something is slapping around in there, but most things have been damped now. I wonder if parts 9 and 18 could be the solution. https://vwcaliforniaclub.com/shop/product/vw-california-wind-out-awning-parts
It was 'fixed' by SMG Tonbridge last year but I suspect this was moving the pads and sending it back out.
