secret lemonade drinker
Actually it all went wrong when VW introduced water cooling!You’ve already missed the boat.
T5.1 was the last of decent Volkswagen build and reliability…
Certainly true for PorscheActually it all went wrong when VW introduced water cooling!
Technically speaking T5.1 with a 1.9 TDI. The 2.5 is known to have its share of issues that can be just as bad as later 2.0 biturbo.You’ve already missed the boat.
No, the 1.9 is a reliable lump that as long as you feed it the correct spec oil runs forever.Isn't the 1.9TDI a true oil burner? I mean lots of oil!
Plus the top doesn’t leak in the rain!You’ve already missed the boat.
The T5.1 came with a 2.0 common rail diesel (CR) engine with 5 different power outputs, 84, 102, 115, 140 and 180bhp formats, no 1.9 TDI. All but the 180 bi-turbo have a great reputation for reliability. The confusion comes from only the German second hand market using (very logically!) T5.1 and T5.2 instead of T5 and T5.1. Most of the world knows the T5.1 as the facelift model from 2010.Technically speaking T5.1 with a 1.9 TDI. The 2.5 is known to have its share of issues that can be just as bad as later 2.0 biturbo.
Last decent van was a T4.2 151ps. They are more expensive than the T5s at times.
Sent from my SM-G991B using Tapatalk
The T5. 1 came with a 2.0 common rail diesel (CR) engine with 5 different power outputs, 84, 102, 115, 140 and 180bhp formats, no 1.9 TDI. All but the 180 bi-turbo have a great reputation for reliability.
Guten Tag! Wie Gehts?unterschiede t5.1 und t5.2
hallo, und jetzt gleich noch ne frage : woran unterscheidet man den t5.1 vom t5.2? geht das anhand der fahrgestellnumer? und was bedeutet im Kfz Schein Typ 7J0? danke für eure antworten axitx-board.de
Entschuldigung, but I am from the homeland and we call the T5.2 with the 2L.
Alles ist gut, das Bier ist kalt und der Blasebalg leckt auch bei 35 Grad Hitze nicht. Gute Reise!Guten Tag! Wie Gehts?
Edited my post above to explain the German model numbers.unterschiede t5.1 und t5.2
Not here, my buddy has 5 of these new Beaches and 3 Ocean sitting with the roof open since April.... I told him to check the roofs for leaking and he laughed.There are plenty of Blasebalg on this site with bees in their bonnets! I hope you are not a sail maker!
Not to nitpick, but in other countries they just call it T5 Facelift.Edited my post above to explain the German model numbers.
Had the T4 88bhp motor, remapped to 150bhp.
Pretty decent motor.
Had the T5 130bhp diesel, killed itself in year 4 at 38k miles.
Had the T5.1 140bhp, peach of an engine. 100% reliable in the 6 years I owned.
Then the T6 180bhp bi-turbo. Great power, not so reliable as stated above.
Pick of the bunch for me, was the T5.1.
In Germany you call vauxhalls opels but they are the sameNot to nitpick, but in other countries they just call it T5 Facelift.
You are mostly correct, but there is a variable that is usually the person behind the wheel... The new TDI are quite good actually, aside from emissions gremlins which end up killing turbos etc.Isn’t the issue with engine reliability intrinsically linked to the efforts to reduce harmful emissions? Remove the DPF, stop start and Adblue technologies and I’m sure the modern diesels will be just as reliable as they were in the T4/T5 (accepting that bi-turbo models add an extra fail point)?
No such things... Opel was in the past a real company with Vauxhall just something the Brits came up with. It was sold as Opel in all of Europe, South Merica, Africa etc. These days they are rebadged Peugeots, Opel is about as alive as Lancia.In Germany you call vauxhalls opels but they are the same
Isn’t the issue with engine reliability intrinsically linked to the efforts to reduce harmful emissions? Remove the DPF, stop start and Adblue technologies and I’m sure the modern diesels will be just as reliable as they were in the T4/T5 (accepting that bi-turbo models add extra complexity & failure point)?
100%.
That and cost cutting. I believe makers decided to cut costs and cover just beyond the warranty period. After that, it’s no longer a manufacturer problem.
Look like the Routemaster gear shift on the bus that took me to school.Most fun, probably the T4.
Can you spot the gear stick mod and a friend acquired out some Jaguar leather … View attachment 127744
Peugeot is dead as well, welcome Stellantis!No such things... Opel was in the past a real company with Vauxhall just something the Brits came up with. It was sold as Opel in all of Europe, South Merica, Africa etc. These days they are rebadged Peugeots, Opel is about as alive as Lancia.
