soulstyledevon
Kennycalifornia
- Messages
- 6,519
- Vehicle
- Cali now sold
It’s probably one of those task that requires it to be done again and again. Easy & quicker once you figured out a routine.
Hi.No, I have a kitchen unit to the right of the door, the toilet protrudes into available space right opposite and to try and put them in with a lift hand turn is obstructed by the fridge unit.
It will be fine, we have got the bikes on and off 4 times before, it Is a faff, one of the things I am looking at is when we finish our ride out from one campsite, and are therefore at our closest location to the next, dropping the bikes off before going back to the caravan, and hitching up the following morning.
I’m certainly prepared to meet you on your journey through Wales to help if required - might even be one of your ‘domestiques’Hi.
Do you have to lift you ebikes on? Or could someone devise a simple ‘ramp’ for you get them on? These bikes are heavy beasts.
Hi.
Hi.
GJ, not familiar with the A frame of an Eriba. Are you able to post a pic so that we can suggest options.
My thought would go towards a small Aluminium C channel, that can be used as a loading ramp?
How about getting a mod to the jockey wheel handle? If it was cut off above the vertical post and bolt head/wheel bolt welded in its place you could use a socket set ratchet drive to wind the jockey wheel up and down. Probably slower than the existing handle but you could operate it with both bikes loaded.Now,
Do take pity on me. I'm as dexterous at solving these problems as someone blindfolded, wearing boxing gloves and trying to sort out a rubrics cube covered in butter.
Bike one is no problem. Two of us just lift on from the front of the hitch.
Then comes the problem of that thing with the red handle. It can't be turned with the second bike in place so the vehicle has to be hitched first. That means it cannot be lifted on over the hitch with creates a little bit of a struggle.
View attachment 73430View attachment 73431
Exactly my thoughts GJ. Cut off that handle. Anyone can weld a bolt on top of it. You can use a ratchet driver to drive it up or down ... and that will solve the problem.
If you want to do it DIY, then cut off the handle and file the end into a square or a hexagon to take an appropriate sized socket.
The upside- no one else can mess around with that handle when you are parked up.
I've just mentioned it to Jo who's had to go for a lie down with a cold towel over her forehead
I'm not too sure if it was the dismembering of her beloved caravan that shook her or the vision of me with a ratchet driver in my hand. I have a family ASBO against me ever using tools![]()
Then ratchet it up a notch with something like the below
Raise and lower at the press of a button ... and between the Cali and the Eriba, there will be enough battery to power that![]()
That is good news.Thank you everyone for all your suggestions above
Knaus have just come back and have offered us their Demo, the one that should have been on display at the NEC until the Caravan show was cancelled.
I'm quite pleased with it, it comes with a load of extras including a ramp to ride bicycle/motorcycle into the van itself which really pleases me.
we want photos photos photos!
That is really good news GJ. ... and also good news for Jo that she will not have to take a saw to her caravan![]()
So loading bicycles was just an excuse. The real reason was all the Tunnocks ... now we know."Now, we have this HUGE garage/locker at the front ..... big enough to take all the boxes of tunnocks wafers that Tunnocks have kindly sponsored us with".
So loading bicycles was just an excuse. The real reason was all the Tunnocks ... now we know.![]()
