K
Kirk
Guest User
We gave up on the aeropress and now just take a small Nespresso machine , we also have installed a slightly larger inverter so we can use it without hook up also.
Can I ask what the glasstop covers you have are please?Good coffee makes our trips in the Cali just that bit more special. We always take a Nespresso Inissia and an Aeroccino milk frother. I love my coffee black but my husband prefers a latte. This works for us on EHU no chance of using the inverter as it’s 1,150-1,260watts (according to the label). We sit ours on the top above the sink. This works for us as we don’t tend to use the sink.
We used to use smart mugs when camping, a cafetière style insulated mug, lovely hot coffee but a pain to clean. Am tempted by the Aeropress for times when not on EHU but fear I may get in a mess, or perhaps I need to research some other device that will use pods...
Bialetti Moka on the gas ring, always use fresh coffee from the fridgeI’ve tried a 12v handpresso - that was/is good. Pods can sometimes break open making a mess and the machine sometimes goes funny but works again after drying out (probably can call that user error!). The pods are not available in shops but can be ordered online.
This one: https://www.handpresso.com/en/handpresso-auto-13.html
I’ve tried a cafetière but it sort of makes too much coffee and is really quite messy with all the coffee grounds and used coffee grounds.
My favourite currently is the minipresso machine. You put the nesspresso pod in and boiling water and use a handpump to make the coffee. I already have nespresso pods and you can get them in most shops.
What are you using?
This one: View attachment 47894
My Husband cut them to shape from penny coin pvc flooring https://www.ebay.co.uk/itm/Stud-Pen...Garage-Workshop-Thick-1M-x-1-5M-/362550927584
But I think you need to be on electric hookup to be able to use it?
+ 1 for the AeroPress
Also have Rombouts individual cup as here
http://www.ebay.co.uk/itm/60-x-Rombouts-Original-Roast-Cup-Size-Coffee-Filters/141439237689
We use our Nespresso Pixie in the van whilst on hookup. But when we're not on EHU we can't use it. It uses somewehere around 1260 watts. So the inverter doesn't help. I know you can alter the Nespresso machine to work at 700 watts but that's still way too much. Wish there would be an easy way to use a Nespresso machine when not on EHU.
thanks for the tip, much appreciated, but that's quite the investment for coffee ;-)
Get the Nanopresso with the NS adapter. Hand-operated, 18 Bars and Nespresso-compatible.We use our Nespresso Pixie in the van whilst on hookup. But when we're not on EHU we can't use it. It uses somewehere around 1260 watts. So the inverter doesn't help. I know you can alter the Nespresso machine to work at 700 watts but that's still way too much. Wish there would be an easy way to use a Nespresso machine when not on EHU.
Yes, boil water and you're doneThat looks like a very nice and affordable solution. However, if you cant use your regular nespresso machine because youre not on EHU, how do you get your hands on hot water? Boil water on the gas stove? Cause that kinda defeats the purpose of an easy nespresso.
Makita - I bet you can drill holes with it as well. Polish the Cali. And “grind” the coffee.Look what i found to make coffee without gas or hook-up
Looks like it works with senseo pads , you could even carry it arround in your backpack while hiking...
How cool! How manly! The second they make one for nespresso cups, I'm parting with my money!Makita - I bet you can drill holes with it as well. Polish the Cali. And “grind” the coffee.![]()
Look what i found to make coffee without gas or hook-up![]()
