DoctorBob
Slightly worried currently - the spec has changed on the config tool for me between placing order and the build; if anyone has a new T6.1 on order (me) in the last couple of months the likelihood is that you will be getting a MY21 base vehicle - this appears to be minus several options you (me) thought was standard - e.g. led lights, side scan, auto wipers - and also several no cost options that may need to be now ticked to make it resealable/attractive to use - such as seats options and removal of balkhead (?me neither?).... i understand specs change between model years, but never seen a situation where that means standard equipment is removed and will cost you more or bundled with other stuff you don’t want post placing the order....
