Grumpy Mike
Both, yes.Is it waste and fresh?
Both, yes.
I agree with that. I drained mine back in October and carry a container of fresh water.I’ve found using my Ocean in the Norwegian winter, the water system works okay in conditions down to somewhere between -5 and -10 as long as the diesel heater is used and the cupboard doors left open. If it gets colder or you don’t do both of the above, the system freezes. The tank is very close to the un-insulated van skin. My advice, if you want to use your van in temperatures below -5, drain the water system. If you are expecting low temperatures around zero, you can still use your water system but you will need to keep the temperature up inside your van and keep the cupboard doors open. If you’re going to have any periods of non-use and the exterior temperatures are likely to drop below 0 degrees, you will need to drain the water system.
Keep it going and it will thaw. My heater has been running continuously for the past 6 days. The van is plugged in as well. Did not bother to empty the tank yet as travelling in a few days to places where the temp is lower than here now in the UK ... so we will see.Currently frozen solid. Tap was pushed off yesterday evening. Temp outside is around -5. Have left the diesel heater on full for about 4 hours now and still no joy ... will keep going and cross fingers!
I meant to drain the fresh water system before the cold snap but I totally forgot and now our system is frozen solid, what are my best options?
1. Leave it alone and thaw naturally?
2. Plug into hook up and put a oil filled heater on a very low settings?
Thanks all
