Fast Freddie
You can buy this type of bag in Sainbury's. We've had one for yearsEssential Purchase today £9.99
Mike
Hi there - do you know if it it still possible easily to push the rear bench all the way back with this installed?Good evening,
I wanted to arrange better access to the full boot space so I got the drawer from CaliCap, Germany.
Today I went almost to Galway to get the best set of Euro boxes to make most of the space:
The drawer was easily installed and looks great. I decided to leave the board on the lower settings, which will have an influence on boot space. I got 6x Euro boxes 400x300x290 and 4x Euro boxes 300x200x120, which I believe gets most out of the available space.
When we are out and about the left 2x boxes will be replaced with 2x of the smaller boxes and (hold on now..) a microwave..
Regards,
Eberhard
All the best
Hi thanks for the detailed response that’s most kind. Could you explain what you mean by the 2-3cm? Can it still be pushed back a long way? We have the fifth seat so like to push it back regularly for the kids to have legroom.Hello,
CaliCap offer two sizes. One size will allow you to push the bench fully back, but the internal drawer size is not ideal for euro boxes. I decided to go for the bigger size. This makes the best out of the space, but the bench cannot be fully pushed back anymore. It is just 2 - 3 cm. So far I can't see a problem with this.
Regards,
Eberhard
Thanks so much for taking the time to write that. All very clear we will be getting one! All the bestGood morning,
Let me try to add some pictures in order to answer your question:
In the picture you see the bench in the most back position. In comparison without the tray in the boot the bench is about 2 - 3 cm further.
So far this doesn't bother me, but I don't use the 5th seat (which is in the garage). I believe there is still enough room left for a 5th seat, but obviously it is a bit less room.
This picture shows the tray in the boot position. Just as close to the door as possible.
This picture shows that the slider of the tray is as close to the bench (again in the most backward position) as possible.
I hope these pictures make it a bit clearer. Maybe you would like to have a look at the manufacturers webpage: https://shop.vwcamper.de/heckauszuege/264/calidrawer-ocean-heckauszug. There are more (and better) pictures.
Regards,
Eberhard
Good morning,
Regards,
Eberhard
it's only fixed at the rear of the tray (closest to the seat) and uses the turn screws part from the vw cool box mounting plate.Don’t suppose you could take more pictures of the frame please. I would like to copy this.
Is it fixed front and back to the sliding rails...?
Where did you get this? Can't find a Zonesleep ultra for the lower Beach bed.I bought a zonesleep ultra for my beach
The last one I built, I fixed it into the rails front and back.
Sounds like the rear only fixing is enough. Just wondering how they did there cross supports. Just out of interest to compare what I did last time. Need to look at building another for my Ocean![]()
Yeah, looks like no cross support.
However, it looks like they do lock into the rails half way down.
This was the previous one I did for my Beach. It is quite different and the original one above maximises the space better. So I could definitely improve my next build.
