kave
I have no exact idea but I guess the eu has the same size? I just ordered a new for my Thule and it fits perfectly.
Yes, it is the standard size. I got my Dealer to make up an extra rear plate.A toss up for me between the Atera Strada DL3 and the Atera Strada Evo 3.
Firstly I presume from the website that you get the same clearance on the Evo as the DL3. Most of the time I shall have 2 bikes but sometimes 3 so when I have 2 will use the rear 2 slots. Going to be for two city bikes most of the time but on occasions my carbon road bike so presume weight is not a problem. Time I made a decision, slightly more room on the Evo is attractive but added weight of 5.4kg. Decisions decisions
Fairly simple one is number plates. Would I be right in saying it is a standard plate size in which case I will get my dealer to get me 2 rear when he orders?
Mike
ThanksYes, it is the standard size. I got my Dealer to make up an extra rear plate.![]()
What type of rack is that on the picture? Looks really good, access to the back, but also the bikes aren't super high.
Hey Brent, looks to me like Atera Della Strada.What type of rack is that on the picture? Looks really good, access to the back, but also the bikes aren't super high.
You're very welcome. I was just wondering myself - there has to be a switch for the rear sensors. Perhaps, I need to retrofit it (if such thing is possible) as it's very annoying to hear beeping all the time.thanks for the fast reply. I was just this second checking that one out. I recently bought a T6 which should have a function that stops the sensors from beeping when something is connected to the towbar so that shouldn't be a problem. I do however want to get in the 2m (and 5cm) carparks. So thanks!
I am away at the moment, with rack on the rear door. It is a pain not being able to get in 2m car parks, as they are the best ones, on the rivers edge etc....but great to be able to use sensors, ....just need to remember that you need to stop at the middle orange line, not the red one!.....I am not going to change thoughHey Brent, looks to me like Atera Della Strada.
http://www.atera.de/en/atera-strada-dl.html
I got it myself as well and it works great, no problem to open the tailgate. When not used folds nicely and fits the space under the bed. The only problem is reversing as the sensors go crazy and make a lot of noise :/ I am now considering changing for the original but that means I might not fit the "up to 2m height" carparks. It's not easy!
Hi
Yes it's the Atera Strada dl3 rack.
I can't recommend it enough. Superb build quality, probably the best I've come across. The rear parking sensors disable when connected, but you get a sign on the dash with a trailer to remind you the rack is there when you select reverse.
I used to own the Volkswagen tailgate rack, but got rid of it. As it limited access into the rear of the vehicle, because you can't lift the rack with the bikes attached. It is possible to lift, but you need to be very strong, plus it will leave dents where the rack attaches to the top of the tailgate. Trust me, been there got the T-shirt.
Another plus point is, you can remove the rack from the van within about 10-15 seconds.
Without doubt hands down, one of the best things we have bought for the van
I don't even have the camera
I am actually thinking about changing for the original (or something similar) more and more these days - next year we're moving to Vancouver, Canada and planning to ship Cali to Newfoundland (or wherever it's cheaper in CAN/USA). Then drive though the whole continent for about 6 months. I will have a roof box on top so no more 2m car parks anyway. Sensors will be the priority.
I fully agree, it is very handy and easy to use rack. For some reason my sensors do not disable when I connect the cable next to tow bar. Does anyone know this can be changed? (2006, 2.5, 174, SE)
Steve I've just tried this with my Canyon CX 56" frame... front wheel off but seat post still in seat tube.... Seat is still higher than Van .. But if you remove seat.. bingo lower than 2m... as you say you will need to design a clamp for front fork to sit in..Hi
I'm hopefully getting a T6 Ocean soon, with the new style VW bike rack fitted. If the bikes are fitted normally the van will be over 2m. As I go to France a lot I'd like to try and avoid going over 2m. Has anyone tried using the rack, with the rear wheel of the bike fixed normally, but the front wheel removed and the forks attached to the rack? You would obviously need to buy a fork clamp for this and fix it to the rack somehow and also of course store the front wheel somewhere.
Trying to work it out from just looking at photos it seems it might just be then no higher than the van roof. I'd be very interested to hear if anyone has tried this and if it works. If so would love to see some photos and also know what fork adapter might fit.
Thanks, Steve
Hi Stephen - i have just come back from 2500 trip around italy with 4 x mountain bikes on the rack. With the bikes protruding above the roof line it affects fuel consumption markedly - the faster you go the greater effect, but i would estimate the bikes reduce fuel efficiency by around 15%. So there is an added reason to tuck the bikes into the slip stream. Having said that, it is a fiddle to make 4 x bikes fit onto the rack and you need a bit of the wiggle room provided by the flexible wheel straps. I am sure there is a solution and i will be looking to reduce drag on the next long trip.Thanks for your replies, Paul and Sam. Sam - I know these are available and have one myself, which is on my car's ladder rack. I'm guessing that the groove on the T6 bike rack might be wider and I was wondering if which off the shelf solution would have bolts wide enough apart to fit. As I said I don't have my van yet, but am just surprised that i have not been able to see any mention of someone trying this before. It seems, on the face of it, to be quite a neat solution to keep the height below 2m, so I was hoping I might get some advice on parts/photos/ or just confirmation that it's an idea worth pursuing and that I havent missed something obvious.
Cheers Steve
Hi
I'm still amazed that no one has come up with a tried and tested way of doing this, with pointers to what extra kit to get. I'm new to Forums and I find it quite confusing to sift through all the threads, so maybe I'm just not finding the information.
I thought it was impossible to open with bikes on?.
The problem with a for mount is the many different wheel axle standards, Trek have yet a new standard this year.
