Annik
Guest User
I guess the rule is don't order any carpet sets till your van arrives!
PossiblyI guess the rule is don't order any carpet sets till your van arrives!
but not if you get a 4 motion because that can only come with 2.I was told 2 rails for my 204PS NOT 4WD
Snowy55, I have been told this is only T6,T5 se's were supplied with 3 rails (just to confuse us I think).3 rails no 5th seat!
My thoughts exactly.Must admit even though our local VW dealer has told us 3 rails (And no 5th seat) i also think i'll await delivery to be absolutely sure. Due to the high cost of the Brandrup carpets and longish leadtimes from Germany (Until the shop hopefully concludes its negotiations) it would be a nightmare to end up with the wrong ones.
Agree with you jabberwocky, unfortunately the configurator may well have information that is 6 or more months old, who knows maybe VW are saving money, all I can tell you is VW uk and my local dealer both believe it to have two rails as standard (the salesman did check the one in the showroom to confirm this). Like I said earlier, changing the carpets will be a pain so I'm going to wait.If you look at VW web site configurator for the Ocean you will find this under the seating options section.
"Preparation for later installation of separate seat, in passenger compartment (1st row of seats) Standard"
It suggests that the third rail is a std fitment if I read this right.
Maybe soon!!
I am told the configurator was updated in June 16, but I still wouldn't take the risk. A few days without carpets between delivery of van and carpets? Worth it to make sure they are the right ones.Agree with you jabberwocky, unfortunately the configurator may well have information that is 6 or more months old, who knows maybe VW are saving money, all I can tell you is VW uk and my local dealer both believe it to have two rails as standard (the salesman did check the one in the showroom to confirm this). Like I said earlier, changing the carpets will be a pain so I'm going to wait.
I have bought brandrup carpets today from local Vw van centre Exeter, my Cali has 3 rails but carpet is for 2, rear seat still moves as it only 2 rails, also bought brandrup seat pockets for front seats, and was offered seat skins but thought too expensive, the local dealer sourced though other dealers and were shipped over nightYou should all wait if you want Brandrup items as they might be for sale thru the webshop soon.....
I think if you run the configurator for a 4motion this line item disappears. My understanding is that the third rail should be fitted as standard to all Ocean models that do not have 4motion.If you look at VW web site configurator for the Ocean you will find this under the seating options section.
Won't the mats be too high where they ride up over the unused rails and foul the seats if you slide them forward??I suppose if you do not intend to install the extra fifth seat in the Cali, you are probably better off ordering the 2 rail Brandrup mats, which would then cover up the unused third rail and prevent debris dropping into it.
You are correct Loz, you can't use 2 rail carpet in a 3 rail van as it damage it.Won't the mats be too high where they ride up over the unused rails and foul the seats if you slide them forward??
Going by Leeky's experience it seems you can fit the 2 rail carpet in a 3 rail configuration whilst using the bench seat.I have bought brandrup carpets today from local Vw van centre Exeter, my Cali has 3 rails but carpet is for 2, rear seat still moves as it only 2 rails, also bought brandrup seat pockets for front seats, and was offered seat skins but thought too expensive, the local dealer sourced though other dealers and were shipped over night
Like I've said, mine is 2015 Cali, with 3 rails, I've fitted brandrup 2 rail carpet, the rear seat still slides, and you can hardly see 3rd rail coveredGoing by Leeky's experience it seems you can fit the 2 rail carpet in a 3 rail configuration whilst using the bench seat.
