briwy
180 Nm I think but pretty sure it in the manual
MMmm that's interesting re copperslip.
Maybe it was some other lubricant my VW Van Centre recommended and put on.
But put something on they did.
I'm slightly alarmed to hear that it's otherwise a matter of pot luck getting a (say punctured) Cali wheel off or not.
I wonder what I would have done if my puncture had been on a lonely road up the West Coast of Scotland well outside moby reach where we spend a good lot of our time?
To say nothing of trips to remote bits of mainland Europe ...
Forgot to add, re-torque after a few hundred miles.Jack up, remove the bolts and if the wheel wont come off put one bolt back in a touch squirt wd40 between the hub and rim go have a cup of tea. Come back hit top of the tyre carefully once with lump hammer or rubber mallet remove the bolt wheel comes off.
Clean the two mating surfaces apply copper slip sparingly and evenly, torque up to 180NM following the correct tightening pattern. don't toque up the puzzle nut you might not get it off again without damage.
Works for me every time.
Having come across this thread a few weeks ago, and also travelling the Scottish West Coast often with no mobile signal, I took our 3 month old Ocean to our dealer for them to take off and on all the wheels so I had peace of mind they wouldn't be 'stuck' if I needed to change a wheel for any reason. The mechanic knew of the issue and gave me a wry grin when he returned from doing the work. All 4 wheels were difficult to remove for them, how I would have managed in the middle of nowhere, on single track roads, heavens knows, so many thanks for the heads up. I am very grateful I had them checked. The service desk guy suggested I owed them £30.00, I suggested it had cost VW a lot less than them having to 'assist' me had I needed to call them out to Sutherland after sunset and he agreed to claim the fee from VW warranty. I hope I never need to swap wheels but I am far happier knowing I will be able to far easier now should the need arise![]()
Glad someone is paying attentionA tip i was given, was to slacken off wheel nuts then lower jack down to release wheel from hub i have tried it once on my bilbos T4 before i had the cali and it did work, hope this works for you
If it it's meant to move,grease it. If not,copperslip. I've always used it and had nothing come loose,I find the studs stay torque up fine. Each to their own though. It's an anti seize compound not a lubricantShould never apply any sort of oil or grease to any wheel studs as they do not torque up correctly & can come loose more easily. Always keep studs dry.
I must be lucky, I’ve not had this problem. My California is in daily use and have tyres changed almost annually because of my annual milage. My local garage that change the tyres have never had a problem removing the wheels and nor have they used any copper grease or any other anti-seize agent. Why?, no idea.
I have the standard VW 17” Thunder Alloys.
I've used copper grease to help stop wheels sticking for more years than I'd like to confess to, with no ill effect that I've noticed. Certainly not seen any increased corrosion as the Textar ad suggest. Shall look a lot closer next time I take the wheels off.Modern ceramic solution with full explanation
https://textar-professional.com/textar-training-center/the-use-of-copper-grease-on-modern-brakes/
