Vwcaliforniajapan
Any experience on upgrading the T5 Euro5 to a Euro6 ?
What’s the cost and how long does it take ?
Unfortunately only one solution. Buy a T6Any experience on upgrading the T5 Euro5 to a Euro6 ?
I read about thisUnfortunately only one solution. Buy a T6
Why are you looking to go to Euro6?
Ok cheers, I thought I could get an euro 6 if I installed something like this product......Why are you looking to go to Euro6?
If you are looking to travel in to cities etc where Euro6 is a requirement, then you are unlikely to get away with any conversion as the van will need to be certified as a Euro6 vehicle. You will not get this.
If you are just looking to drive a 'cleaner diesel' then this device may satisfy some of your requirements, but nothing more.
As has been said before, you really need to reinvest your money in a certified Euro6 vehicle.
No all you'll have is a Euro5+device van.Ok cheers, I thought I could get an euro 6 if I installed something like this product......
I know that you can get a Ducato from euro 3 to euro 4 just byI thought in Germany there was a way to get a Euro 3 vehicle classified as a 4 by fitting a device.....the details are irrelevant other than if my memory is correct, it was an example of a Government accepting an add-on as a way to jump up a class of emissions.
Yeah, clearly the task is different but it wouldn't be worth doing it (financially) if t couldn't be recognised by the authorities. The fact is happened as you described, might give the OP hope.I know that you can get a Ducato from euro 3 to euro 4 just by
fitting a DPF.
I think with euro6 there is a lot more involved, adblue and possibly
stop/start to name a couple.
I think this is a different system.I wonder why no Manufacturers have taken up the Bosch System.
The Bosch System is the same system as used on the T6 but fitted differently. Still uses Adblue and is not suitable as a retrofit.I think this is a different system.
http://www.amminex.com
Looks like this in the boot. View attachment 42221
Will it be any improvement on the VW engine?Thanks, I better look at the V class new Diesel engine then. I guess MP will have it in 2020.
