Tool for tightning/losening the gas-safety valve
Still no good for hands like mine with no grip! But good tip anyway.
Grip is not so important - there is a collar that just needs pulling inline with the connector. Some good camping stores sell the connector, it might be worth locating one and just try it.
Perfect, thanks
Alan
I solved the problem by fitting the Calor combined regulator and tap with an in-line quick release gas fitting.
Now it's easy to check if there is any gas by just releasing the in-line fitting and lifting the cylinder and giving a shake.
The VW system is one of the most awkward tap/regulator combinations I have ever seen.
@WelshGas I'm considering your conversion to the Camping regulator, I was looking at a way of preserving the old hose in case I want to go back to the original setup. Do you think this cardiac QR would screw straight on to the spigot at the water tank? https://www.cadacinternational.com/uk/quick-release-coupling/ I could then connect a new regulator and hose on to it.
Sorry, no idea. I just bought a spare hose as the Calor Campingaz regulator requires the fitting on the VW hose to be removed. NB, the VW hose is not a simple red rubber hose. It has a very significant internal polyurethane lining. Had to use a heat gun to soften it to push fit on the connectors.
The club shop sell the Gok pigtail if you need to replace it.
That link says `These items must be replaced every five years`
Have they made new regs for these in the UK? i've just checked
the german regs again and its still 10 yrs over here.
Could be it's not on theire webshop did not check myself , i saw it in the showroom last week when i was there myself . It has GOK on it witch i think is a gas equipment suplier . Try and search using that maybe?
@AlanC
EDIT : found it even cheaper
https://www.obelink.nl/gok-gasflessleutel-blauw.html
https://www.google.be/search?q=gok+gas+sleutel&ie=UTF-8&oe=UTF-8&hl=nl-be&client=safari
Now on Amazon but £10!
https://www.amazon.co.uk/dp/B074JZR48K/?tag=unique09f-21
8K
bvddobb
bvddobb
Calimeup
BerndRos
BerndRos
Moakesy
Moakesy
Moakesy
CALIBEACH83
11K
Amarillo
Amarillo
RobertCalifornia
yossarian
Y
