12v TV troubleshooting
Mcvisto
Galway
T6 Coast 150
I have a 12v TV that previously worked but now won't start up unless on EHU. It 'tries' to start and flickers briefly so getting power but maybe not enough? 12v socket is working fine for everything else. Any suggestions as to how to fix?
What voltage is shown on the Control Panel?
Control panel showing 12.8 v
Could be a poor connection in the 12v socket.
You could try it in another 12v socket, by sliding door.
Measure the voltage using a plug in voltmeter on the 12v socket being used.
Thanks WelshGas, tried the other 12v sockets but no joy, same issue.
try it in another vehicle ?
Will try the inverter option for sure. Tried it in another car earlier but had same problem so at least it ruled out the California! Had another look at the 12v cable and replaced the glass fuse with one from another plug in and hey presto, it worked! Thanks for all the replies
Meoncoast
16K
Amarillo
Amarillo
aBusAndBeyond
aBusAndBeyond
aBusAndBeyond
Brownbetty
Brownbetty
Brownbetty
