R
Rooster
Pretty new in this lovely forum. Anybody to tell me how to vent air in the cooling system?. Thx.
the main coolant flow will be around the engine and radiators via the water pump. only a small flow will go up to the header tank through expansion. sometimes they are called expansion tanksThanks, Perfectos and Flying Banana for your prompt responses. Much appreciated!
1. Yes, I did a full drainage and filled the system with a new cooling water. However I was not sure that air has been expelled from the system.
2. Flying Banana, grateful for your response. Indeed I checked that there is a steady feed back to the header tank. However the volume flow is not very high. I take it this is normal.
Greetings
Great! That completes the response and closes the case.Thanks again.the main coolant flow will be around the engine and radiators via the water pump. only a small flow will go up to the header tank through expansion. sometimes they are called expansion tanks
