You have a leak of combustion gases into the coolant system, probably exhaust. This is pressurising the coolant system causing the coolant pipes , engine radiator and internal heater matrix to expand and that is where your coolant is apparently disappearing. When the pressure is released by removing the cap then the coolant reappears as the whole coolant system returns to its normal size/volume.And in fact, the "leak" is very minimal - the most important problem seems to be the pressure building up...
This will get worse with time until part of the coolant system will rupture. Messy if it is within the engine compartment and very, very messy if it is in the car heater matrix within the dashboard. Also much more expensive.
This gas leak is probably from the cylinder head but could also be from the EGR valve cooler.
I would not drive any great distance until fixed.
