Grumpy Mike
Got sensors from BMW on e bayApologies if you have already said this but where did you get the sensors from? I wonder if one has failed?
Welsh Gas. You say reset/clear. But which buttons?Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
It’s a while since I have done this but I think when you’re in the diagnostic menu and you scroll with wheel that one of the options is ‘clear’. You press the button to do it I think.Welsh Gas. You say reset/clear. But which buttons?
As @Lambeth Cali has said. The screen will tell you.Welsh Gas. You say reset/clear. But which buttons?
Same fault here on our 2014 cali. Roof won't go up. Fault 1000.Now I've solved the problem on the roof fault. Firstly I had to manually power up the hydraulic pump through the two pin connector block near the motor. This let me raise the roof safely without damage.
Which then allowed me to insect the four magnetic sensors on the hydraulic rams. Two had shown previous signs of repair so I decided to replace them all. The part was only available as a complete loom from the dealer(not cheap). Decided to cut the 4 four sensors out and connect them the the vehicle loom making good the insulation.
The fault code erased immediately and full function was restored.
This might help.Same fault here on our 2014 cali. Roof won't go up. Fault 1000.
Frustratingly after a reset it shows the roof as down until ignition is on, then roof up flashing starts.
Is there any instruction anywhere about how to get to the point as in pic above of actually accessing the connector block for the motor? I've taken out as much trim as it's obvious how to remove, and I'm a little wary of breaking anything by trying to force the wrong thing! Don't want my efforts to do a cheap fix with the sensor replacement to result in me causing more damage by cutting out that foam and slicing through something else!
Thanks a lot! Will check it out.This might help.
Sadly this appears to be taking out the whole cab headliner, and that's something I'm going to try and avoid. Looks like a bigger job than I've got the appetite or space for.This might help.
