Hi HowieDog, please could you share details of the 6kg bottle you have bought? We have been looking at Gasit and a few others, we Don’t want a gas point, just a bottle we can fill that will do us for Europe as well as UK.Just got Gaslow for our new Hymer van.One off cost c £300 but now it only costs £9 to fill a 6kg bottle with LPG and no faffing around swapping cylinders over.
It refers to portable, a refillable is still portable, until you plumb in a refilling point on the van, at which point it ia no longer classes as portable and it is permitted to fill at service stations. That said, whilst some won’t, many petrol stations allow the filling of portable Gaslow type cylinders.I've seen many many of these threads just go around in circles once the legal aspect is raised. The link you posted refers to filling non-refillable cylinders at a service station which is slightly off topic (as are the legalities). May I respectfully suggest a seperate thread for the legalities and confine this one to the technicalities?
Putting aside the filling of 907’s with propane…..the issue I have and many others on here is the EYE WATERING PRICE charged for 907 refills. I haven’t bought one for a while but I believe they are around £35 to £38 here in the UK. We’re off to France next month so will exchange there for about £22 which is a little better.Do NOT fill your 907 with propane! The bottle is not designed for the higher pressure. That’s the advice from a former manager at AirLiquide .
Instead switch to a 2012 propane bottle. Fits a little more tight to the van. Also beware of the 10 year lifetime if you find the slightly smaller 2006 bottle still available at some suppliers. But what’s your issue with butane if you not plan to use the van in colder conditions?
Do NOT fill your 907 with propane! The bottle is not designed for the higher pressure. That’s the advice from a former manager at AirLiquide . Instead switch to a 2012 propane bottle. Fits a little more tight to the van. Also beware of the 10 year lifetime if you find the slightly smaller 2006 bottle still available at some suppliers. But what’s your issue with butane if you not plan to use the van in colder conditions?
If your 907 is stamped with Butane and Propane there is no issue at all providing you reduce the the volume of liquid gas.Do NOT fill your 907 with propane! The bottle is not designed for the higher pressure. That’s the advice from a former manager at AirLiquide .
Hello Chocksaway, I imported at Cali from Germany to British Columbia and over here butane in bulk is not used or available for 907s or any other cylinders. I had a hydraulic hose shop attached the butane male end fitting to a single stage propane regulator and bought a 5 lb. propane bottle that fit into the Cali's bottle well. The 5 lb. is slightly taller than the butane, so I cut 3/8" off the bottom 'stand up' ring on the bottom and then fashioned a 3/8" spacer on the screw on lid to give me enough clearance for the overall height. It all works fine.I am thinking about the possibility of fitting a Gaslow 2.7 kg refillable in place of the 907. Has anyone else done this? How did you go about it? In our previous PVC’s we had Gaslow, in fact we still have two refillable’s in the garage but as they are 11kg and 6 kg no use to me right now!
As best as I can tell from the manual the only change I will need to make is the regulator.
Any thoughts and advice welcomed.
Now then, I agree the price to change is eye watering but I reckon I can sell the 6kg bottle and use the money towards a 2.7. Then I can refill the 11kg cylinder at my friendly depot in Edinburgh and use that one to refill the 2.7 at home. I use to fly hot air balloons and the prospect of refilling does not phase me at all (it’s just common sense and the right gear).
All seems too easy…….. tell what I’ve missed![]()
Kind regards
Alun
For anyone considering the Gaslow 2.7 for California’s with the gas locker inside the water tank …….. I checked with Gaslow HQ and they said the cylinder is just a little to high to fit inside and still put the lid back on
Back to the drawing board …….![]()
Now that’s a good ideaWhat about someone 3d printing a new domed screw on lid to give a bit more hight?
There are suppliers on Multicoloured auction site sellling the whole kits, just specify Butane to 907 etc and it should come up In a searchOK.... it looks like i need this part for the Calor end...
Cavagna 21mm Clip-On Gas Bottle Adaptor
Upgrade your LPG system effortlessly with the Cavagna 21mm Clip-On Gas Cylinder Adapter, the perfect solution for adapting international gas bottle fittings to the standards used in your locality. This high-quality, precision-engineered adapter is a must-have for anyone looking to ensure a...www.gasproducts.co.uk
@Perfectos @yossarian thanks chapsOK.... it looks like i need this part for the Calor end...
I've sent you a PMDoes anyone know the thread size/reference for the GOK fitting that VW supply on the 907?
@Perfectos @yossarian thanks chaps![]()
What would a non return valve do for me? I can just vent the hose after the transfer is complete (never had NRV’s on hot air balloons)There are suppliers on Multicoloured auction site sellling the whole kits, just specify Butane to 907 etc and it should come up In a search
tip, ask for a non return valve to be supplied with the kit, note you will have to assemble to fittings / hose etc, despite the listings showing a complete assembly
Good for you, enjoyWhat would a non return valve do for me? I can just vent the hose after the transfer is complete (never had NRV’s on hot air balloons)
Hey Perfectos, it was a real questionGood for you, enjoy
And I called GasLow and they told me they DO fit! Sigh…For anyone considering the Gaslow 2.7 for California’s with the gas locker inside the water tank …….. I checked with Gaslow HQ and they said the cylinder is just a little to high to fit inside and still put the lid back on
It’s just an added safety feature. Not essential, but good practiceHey Perfectos, it was a real questionI meant is there something I should know about re the NRV?
