JuanVecino2023
Think mine may have to go in for this. Despite early positivity, over the summer it’s spread by a bigger leak than the Titanic.The 05S will have additional black waterproofing membrane along the horizontal and zipper seams
Is this actually labelled 06S or is it an “enhanced” 05S?Over on Calibord.de, 06S bellows have been installed....
These appear to have a transparent seam tape over the two vertical seams, which, if I've followed the latest posts here were the last one's to remain untreated.
I ripped a photo from their site...
From what I can gather it's a new product variant ie 06SIs this actually labelled 06S or is it an “enhanced” 05S?
Mine has gone in today for new bellows. I asked about the 06S. He said they’ve only fitting 05S but some 05S may have some enhancements, or something along those lines. It may just be dealership speak of course.From what I can gather it's a new product variant ie 06S
I have been in touch with VWEO as mine is waiting to go in to get 05S fitted. VWEO are unaware of 06S and have asked for an update from factory technical on this. Guess need to wait and see what the situation is, Rhiannon is going to call me when she has this information.Mine has gone in today for new bellows. I asked about the 06S. He said they’ve only fitting 05S but some 05S may have some enhancements, or something along those lines. It may just be dealership speak of course.
FIFY. Seems more appropriateThis all seems reminiscent of previous new iterations of the bellows where the first we hear is from calibord, then FLOOD (sorry) into the UK.
Mine has been doing this since new. Its going in for a long list of niggles on the 17th. I will inquire re the 06S bellows as I'm in Germany. The slow boat to the UK hasn't left port.In addition, we've just discovered that we also have a leak in the tailgate. It's coming through between the rubber seal and the door. Nothing like a refreshing drip on the head at 3am!
Tailgate seal an easy adjustment to make leak free. Most seem to have this issue.Mine has been doing this since new. Its going in for a long list of niggles on the 17th. I will inquire re the 06S bellows as I'm in Germany. The slow boat to the UK hasn't left port.
Tried that and didn't workTailgate seal an easy adjustment to make leak free. Most seem to have this issue.
Good to hear, so what's the adjustment?Tailgate seal an easy adjustment to make leak free. Most seem to have this issue.
Not David Wilson or Bellway?House.
Yank on it to pull it away from the lip to which its attached. Its on pretty tight so needs firm adjustments. The idea is that the seal presses harder against the tailgate. Personally I think the water is is gaining access behind the seal.Good to hear, so what's the adjustment?
Yeah, I also tried that tooYank on it to pull it away from the lip to which its attached. Its on pretty tight so needs firm adjustments. The idea is that the seal presses harder against the tailgate. Personally I think the water is is gaining access behind the seal.
Yeah its called pipe insulation tubing cut to fit, so that water never reaches the VW 'seal'Perhaps someone should develop a Tailgate topper!!! ...and then VWEO could furnish us all with one of those as well![]()
Strange, worked perfectly for me.Yeah, I also tried that tooDidn't work!
Number 1 in the UK!!!!Just had my 06s bellows fitted dealer did not know until i looked at label back at home, thought they were 05s :-}
Am i the first?
Lets hope 3rd times a charm.Number 1 in the UK!!!!
Very interested to know if you see any differences from 05S (specifically the corner vertical seams)Just had my 06s bellows fitted dealer did not know until i looked at label back at home, thought they were 05s :-}
Am i the first?
Alot of seams are now tapped, not sure what i had befor but material seems tighter with minimal pin holes had it up over night in rain to test on drive all bone dry so far!Very interested to know if you see any differences from 05S (specifically the corner vertical seams)
