T
tobydogplaystation
Paid £375 for first service and “free” inspection. Legalised robbery.hi just been quoted £410 for a oil change visual check and mot what's everyone's thoughts?
I do the same, cost has gone up a bit for oil & filters but still considerably lower cost than a VW dealer.Over the past twenty years I have had the following new, 1xT4, 3xT5 & 1xT6, did all the services and repairs myself except a cam belt and waterpump on the T4 and similar on the T6. Where necessary genuine parts were used to maintain the warranty.
I'll leave you to calculate how much I saved.
Some questionable costs in there. An oil filter that costs more than 7 litres of oil? (Asssuming 7 litre engine oil capacity) What brand of oil sells for £5.60/litre?All in £249.34
It’s a Vw part it has one year left on the warranty so worth putting genuine part on,but we’ll spotted the cabin filter is the oil filter and the oil filter is the pollen filter the guy in the garage put the wrong prices against these two lolCrumbs....expensive filter.
Just changed the oil in my CRF1000. 1400miles old and it was like new..... (its had some abuse off road so I thought better safe than sorry). Filter was cheap but it’s the one to go for, the oil is also the one to go for, but wow...expensive. Never seen so much oil come out of a motorbike
WeSome questionable costs in there. An oil filter that costs more than 7 litres of oil? (Asssuming 7 litre engine oil capacity) What brand of oil sells for £5.60/litre?
Owned my first car in 1966 and have never had a garage oil change/service. The most difficult part nowadays is disposing of the waste oil. And remember when you fitted a replacement copper sump washer costing 5p as opposed to a complete plug costing £3.30?
Unreal ,i think people should stop using these overpriced main dealers going forward they are going to struggle less new cars getting bought and more people will be hanging onto older vehicles,also the ev vehicles don’t need the level of servicing so they will be looking for ways to make up the short fall.My wife has a very lightly used Mazda Cx30. It went for it's second service last week. 2 years old and only 1200 miles on it! £385! They then had the brass neck to suggest the front discs and pads should be changed due to some surface rust due to lack of use. £500.
If you find a good independent garage and ask them to service the vehicle using VW parts there shouldn’t be any wiggle room.I guess you have to balance the indy vs franchise routes. In warranty I'd always say go franchise, it protects you more and removes any wiggle room if something goes wrong. Out of warranty a good indy can be cheaper, but a good franchise can be more beneficial in the long run.
All that said, 410 seems a little steep and the @pjm-84 recommendation for a service plan a sound one. 55 quid of that is the MOT, so it's 360. They haven't tacked on air con or brakes have they, which is a trend nowadays? Their national prices are below, so there is a discrepancy of about 75 quid.
Technically (and legally) correct, thanks to block exemption. As long as OEM parts are used and the service carried out to OEM standards, legally anyone can do a service. The latter point though is where OEM's can complain and say they did not carry out to the right standards in case of a warranty claim related to the area serviced.If you find a good independent garage and ask them to service the vehicle using VW parts there shouldn’t be any wiggle room.
Never said they were. Just pointing out how an OEM could frame it. You could end up with two garages pointing fingers at each other for the sake of a few pennies on a 70K investment. After warranty, I'd be looking for a good reputable indy.But surely if something serious happens like a siezed engine or a serious leak then you would take it up with the garage that did the work.
Even a main dealer can cock up and they will try and put the onus on you.
Not all independent garages are rogues …
I think the key point here is "independent mercedes specialist" rather than just an independent.I have used an independent mercedes specialist since my mercedes was new, the independent has the mercedes software and diagnostics and access to the digital service records, it needed warranty work which mercedes UK authorised without issue
Block Exemption does say they don't need to be OEM parts, just parts of a comparable quality. In the 80s and 90's OEM's ran an absolute racket with parts and servicing restrictions and BE was the answer to that.We have a 2020 focus ST line and we took out a Ford Protect extra warranty which is a bargain at just over £200. I phoned them to clarify what garage I needed to take it to to make sure the warranty would be honoured and was told that I didn’t even have to specify OEM parts they could be parts that the VAT registered garage usually uses.Although I did ask them to use OEM parts just in case. With 3 spark plugs at £80 I’m sure I could have saved myself a good few quid using equivalent parts.
But VW give a 2yr Warranty on their work be it a repair or a service. How many Independents do?But surely if something serious happens like a siezed engine or a serious leak then you would take it up with the garage that did the work.
So basically a Franchise, and I'm sure they had to pay Mercedes to offer those services.I have used an independent mercedes specialist since my mercedes was new, the independent has the mercedes software and diagnostics and access to the digital service records, it needed warranty work which mercedes UK authorised without issue
That's true but at the same time do you really, really need a warranty on an oil and filter change? If they'd some something identifiably stupid like (struggling to think of one...) okay, not done up the sump plug properly and it fell out, you'd know about it pretty soon.But VW give a 2yr Warranty on their work be it a repair or a service. How many Independents do?
