Outdoor Revolution Rechargeable Tube Pump - 35W (NEW FOR 2024)
Outdoor Revolution Rechargeable Tube Pump – 35W (NEW FOR 2024)
£49.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 5060542531085 Categories: , , , ,
Designed to be small, compact yet efficient, the new Rechargeable Tube Pump from Outdoor Revolution is the perfect addition to your camping set-up.
Specifically designed for the inflation of air tents and air awnings with inflatable tubes to a maximum pressure capacity of 10psi.
Constructed from robust ABS, this compact pump is supplied with adaptors to fit the Outdoor Revolution DSV Type valve as well as the traditional Boston style valve.
Due to is measuring only 8cm x 15cm, the rechargeable tube pump is supplied with a handy drawstring pouch and can be easily stored and carried without having to worry about where you can fit it in your campervan or car.
The main feature of the Tube Pump is that it’s rechargeable, meaning air awnings and tents can be inflated even when away from a mains connection or 12v connection, simply charge the pump up beforehand and it will be good to go.
Supplied with a 50cm USB charging cable, 50cm air hose with valve adaptors & a handy drawstring pouch.
  • Battery capacity – 12v – 2000mAh
  • Power output – 35W
  • Charging voltage – 5v- 2A
  • Charging time – 4.5hrs
  • Max pressure – 10psi
  • Air flow – 30L per minute
  • Weight: 0.84kg
  • Certification: CE, UKCA
PUMP2209
Be the first to review “Outdoor Revolution Rechargeable Tube Pump – 35W (NEW FOR 2024)”
£49.99 Inc VAT
