VW California T6 / T6.1 Easy Fit Drawer Kit
The Easy fit drawer kit has been specially designed for the VW California. They fit in the right-hand cupboard under the sink, and you can still close the door. This handy drawer unit will be a great addition to your van, allowing you to store your items neat and tidy.
Made from the original VW drawers and soft-close runners which will match the original drawer in your van perfectly.
- Very handy storage solution.
- Made with the Original VW drawers.
- 3 drawers
- Soft-close runners
- No drilling required
The 2 rails come with 3 runners attached and ready to fit.
Kit contains :
- 2 rails with 3 runners attached to each one and heavy-duty double-sided tape attached.
- 3 Original drawers
- 2 alcohol wipes
Frequently bought together
Reviews (19)
19 reviews for VW California T6 / T6.1 Easy Fit Drawer Kit
You may also like…
Brandrup Velour carpet for passenger compartment, VW T6/T5 California Ocean/SE “Palladium” – Two Rails
£184.99 Inc VAT
Alan Mead (verified owner) –
Well, I’ve fitted them, and they look really neat – 5 stars for looks. It took me somewhat longer than the guy in the video – mostly time spent plucking up courage to position the runners, knowing that once in place I’d not be able to move them. I thought I’d got it right but probably one millimetre further back would have been better as the drawer fronts just caught the sliding door at first, until I forced home the tangs to their maximum extent. It’s still close. Having now shifted the Ridgemonkeys and other assorted cooking items to the other cupboard, I’m now wondering where I’m going to place tall food items. I dream of driving with a clear rear compartment but am beginning to wonder if a large “really useful” plastic box might now be required for the food. If only I could convert the wardrobe to an easily accessible larder. Very pleased with the drawers though and the only reason I’ve given 4 stars is that they are a tad expensive (although I see the remaining one in stock is £41 cheaper).
kevfrombournemouth (verified owner) –
Another great product, but had similar problems with alignment, fitting in our 2020 T6.1 Ocean. I wondered whether the T6.1 cupboards curvature is slightly more defined, therefore you need to position a couple of millimetres behind the existing draws front frame alignment, this avoids them catching the door, when closed.
They look great and makes storage, so much easier. Would recommend, just take care when fitting.
David Brown (verified owner) –
Quality product, really easy to fit. Expensive but seem worth it.
Julie Livingstone (verified owner) –
Very pleased with these drawers, easy to fit and work nicely with the soft close. It’s a shame that the shelf taken out cannot simply be fitted to the left side without the need for drilling additional holes.
Bigrodders (verified owner) –
Easy to fit and excellent quality, the wife loves them
anthony.farrar (verified owner) –
Excellent product. I fitted them to my T5 although I was told you couldn’t. A member of the California Owner’s club illustrated a way of doing it. I fitted them and the sliding door hit them. It is possible to move them once they are stuck – a bit of leaverage is required. I ended up with two kettles left over (normal and electric) as they could not fit anywhere. Moved them next door. Overall a useful and much more convenient method of storage. Expensive but once you have spent the money, don’t think about it.
Vernon Hall (verified owner) –
Fairly easy to fit.
The only issue is the lack of a way to secure the rear of the drawer runner to the drawer unit.
If you open the draws fully they disengage from the runner.
I ended up using duct tape to secure, which was a faff and not ideal.
Paul Jackson (verified owner) –
I ordered these to improve the overall storage capacity and ease of storage of my T6 Ocean. I found them extremely easy to install but less easy to adjust to get the best setup.
Watch the video it is helpful but clearly this is being done by someone who is very familiar with the process, once the runners are in place they would be extremely difficult to remove.
My lessons would be;
Check the measurements as they are given in the instructions and then tighten the screws. If they are loose when you try and install the drawer it will move and you have to measure and adjust again.
Make sure the rear tangs are square, they are easy to adjust with long nosed pliers.
I would recommend installing 3mm back from the existing drawer, reason for this is that if you adjust the height the sliding catch on the cupboard will be compromised and makes it difficult to open.
Great product, well designed and adds value to the van.
Mark Connelly (verified owner) –
A great addition to the California. Easy to fit but worth making sure you are happy with the position before sticking to the unit sides. The height of the drawers are adjustable allowing you to space the drawers for taller items.
James Dorman (verified owner) –
My favourite item I’ve bought for my California. This brings a new level of organisation to the van. Before it seemed like I would have to move five things to get to the thing I wanted – not anymore as now most of my commonly used things have their own drawer. Very well made. It took some courage to finally peel off the tape and stick it on – and only after about 15 minutes of checking measurements and re-checking measurements. Love it
Cate Davidson (verified owner) –
Really love these drawers, they have saved us from the morning Ikea box shuffle to make a cup of tea. I would definitely recommend watching the installation video in advance of fitting, made it fairly easy and gave me reassurance before taking the leap with the sticky stuff! From my point of view a great asset to the van and well worth the expense.
Ian Fraser (verified owner) –
Drawers look good easy to fit. But negatives were both frames were misshaped and badly packaged and I had to rebuild and realign the frames.
One of the boxes of the drawers was open and the packaging inside was also unsealed compared to the other two. I think it had been a returned item.
Not good enough really for the price. I think I should have been informed it was a returned item. Took the shine off them a bit😡
Ben Stevens (verified owner) –
Wow…. Simply fabulous.
We held off from buying these for a couple of years as we just wouldn’t believe the hype.l but I can tell you that they have transformed our storage solutions beyond belief.
They are super easy to fit, feel sturdy and actually can store much more than you think. What a superb addition to our much loved Cali.
I must say Campervanbits have been amazing too. Prompt service and delivery with this and any purchase we make.
Thank you 😊
Ian Callender (verified owner) –
Yes I know, THE PRICE; however, once we’d decided that this is something we ‘required’ and it was delivered I haven’t regretted it one bit.
They is easy to fit (although I have added non-slip matting in the drawers) and looks like they’ve always been there. We now have much better use of the space and moreover it’s so easy to get to everything (rather than the usual ‘rummage’).
Still unsure why these aren’t available for the other side of the cupboard.
One last thing, don’t forget to use you membership discount (-5%).
mattsv (verified owner) –
Love these drawers – no more having to slide out multiple Ikea boxes trying to find what you are looking for. Everything now has its own allocated space, easy to access. OEM quality – not cheap, but probably much cheaper than if they were an option from the factory!
Clair Evans (verified owner) –
Item was received quickly. The YouTube video was a great help and made installation easy. Very impressed with the quality of the product and highly recommend CampervanBits for all your accessory needs.
Nigel Mulholland (verified owner) –
Great item to have fitted in the Cali! Easy to fit (very helpful demo video), excellent quality and allows easy access to stored items. The amount of available storage is surprisingly good. Great service as always from CampervanBits. I’m very pleased with this purchase.
William Lee (verified owner) –
Very happy with this item – fitted easily following the instruction video and it works well. Also, excellent customer service from CampervanBits: the item they originally sent to me was damaged in transit but when I raised this with them, they dispatched a new item straight away (with no quibbles) and made the return of the damaged item very easy with excellent communication throughout the process – 5 stars for customer service alone.
ian.tidey-4550 (verified owner) –
Really great drawers, they have saved us from the morning Ikea box shuffle to have a coffee or get the plates out. I would definitely recommend watching the installation video in advance of fitting, made it fairly easy and gave me reassurance before taking the leap with the sticky stuff! A great asset to the van but they are expensive
