J0HNM
Just sharing my recent experience with a failure of the Adblue pump in my 6.1 Ocean (MY21).
Shortly after driving off the ferry in Santander I got the yellow engine-outline warning light so drove to nearest VW agent (in Torrelavega about 20k from Santander). The garage was very good and diagnosed the problem was failure of the Adblue pump. Within a few days a new pump had been fitted but the garage said they weren't able to 'configure' it and that they were in communication with VW head office for guidance.
Over several days they were told to try certain things but none worked. Eventually the problem was discovered to be a fault with the software garages use for diagnosing and configuration. The work-around solution was to use a 'different channel' to configure the pump. Apparently it is normal to use the same channel to configure a component as well as diagnose issues. But with the Adblue pump scenario a software bug prevents this and it was only when a different channel was used that they could successfully configure the newly fitted pump.
My communication with the garage was via Google translate so some of the terminology above may be inexact but I thought it worth sharing and the gist of the message should be accurate enough.
