As stated - SUV. 235 -55-17-103-YHi @WelshGas were your Michelin cross climates the “Agellis” ones?
Thanks in advance
Thanks in advance
So I would suggest the difference in wear issue is due to @WelshGas having a 4 wheel drive and @Geesvw having a 2 wheel drive.
I posted many years ago that one of the reasons I went for a 4 motion was the experience of 10 years and a 150k with a 2 Litre Touran with FWD. I’d like to think I’m a pretty smooth driver but front wheel spin when pulling away was an issue.
So each to their own but personalIy I would quite happily spec a 150hp 2 wheel drive Cali but anything above and it would be a 4 Motion. If I already had the high powered FWD and needed winter tyres I’d be switching wheels to specific winter tyres.
I think this issue highlights that there are very few hard and fast rules and we each have slightly different circumstances. No doubt why there often appears to be disagreement when in fact there is none.
Mike
Black circle currently have a deal on so going for these:-
Michelin CrossClimate SUV
235/55 R17 V (103)
4 x 4 Tyre - Reinforced
Voucher code is CC40
Total £514.40 fitted
Free Tracking check
Mike
Look on your current tyre sidewall for size / load and speed rating. i would expect they are 235/55 17 size
Is that the only size on the label? My label lists both 17" sizes, as well as the two 16" sizes that were fitted the year my van was made.My tyres are 215/60/R17 , that's what it says on the label on the pillar so where does it say I can use 235?
Are you sure? It usually lists several sizes. With a 204, yours is very surprising news.On the door pillar on my T6 it does not mention
235/55 R17 V, it says 215/60/R17
What should I be ordering ? Confused
Forget the pilar look at the tyre. Never heard of a T6 204 ocean on 215 tyres. The pillar label just tells the pressure for a range of sizes. You need to look at the tyre sidewall.My tyres are 215/60/R17 , that's what it says on the label on the pillar so where does it say I can use 235?
I just got those at Kwik Fit, through their website, fitted at local branch, for £511.00Black circle currently have a deal on so going for these:-
235/55 R17 V (103)
Free Tracking check
Mike
To me, the pillar tells you the choices you have that keep you 'standard' from an insurance point of view. I WOULD look at the label. If you just look at the tyre, and a previous owner put an non standard / non load rated tyre on, you'd just repeat the error.The pillar label just tells the pressure for a range of sizes. You need to look at the tyre sidewall.
It's more likely to have come on 215's, as did my T6 150, but it had the 235 size on the sticker/label as well.Sorry guys, I appear to have not updated my profile, I now have a 150 , does that make a difference?
Yes, It could have come fitted with 215's, but the label should have the option of fitting 235'sSorry guys, I appear to have not updated my profile, I now have a 150 , does that make a difference?
After almost 3 years on the same set of Bridgestones its time for me to shop for new tyres. Been looking at Crossclimates today and although Agilis are meant for vans you can't buy them in 235/55 R17. Shame really as the suggested extra durability is appealing. So if I go for these its a toss-up between SUV and +. Probably the latter for my 2WD Beach.I fitted a pair of these to my front wheels a couple of years ago, and I must say they're really overrated
The rubber is so soft, only lasted 10K miles, for average mild UK winters, not entirely necessary, despite decent grip in the rain.
If you are going to purchase, make sure you buy "Agilis" Cross Climate as they're designed for a transporter/California
I've now fitted "Goodyear Marathon Cargo" tyres at a fraction of the Cross Climate tyres price - now after 10K miles, they have no great sign of wear!
Yep, it's complex. The Agilis is available for the 215x60 size fitted to some Cali's. They have a very high load rating (107/109) and have a very different pattern to the SUV and the + models.After almost 3 years on the same set of Bridgestones its time for me to shop for new tyres. Been looking at Crossclimates today and although Agilis are meant for vans you can't buy them in 235/55 R17. Shame really as the suggested extra durability is appealing. So if I go for these its a toss-up between SUV and +. Probably the latter for my 2WD Beach.
The CrossClimate+ and SUV are both available in a 103 load rating according to Blackcircles' web site.Yep, it's complex. The Agilis is available for the 215x60 size fitted to some Cali's. They have a very high load rating (107/109) and have a very different pattern to the SUV and the + models.
What's the load rating of the + model in the 235s? I went for the 235 SUV following my own thread on the confusing choice.
I wonder what the difference is then? I ordered the SUV expecting (not hoping just expecting) them to have the central rib as shown in most of the photos, but they haven't.....they have the same pattern as the +. (i did check they'd sent the right ones, and they had).The CrossClimate+ and SUV are both available in a 103 load rating according to Blackcircles' web site.
Get the SUV version as more suited to the weight of a cali.After almost 3 years on the same set of Bridgestones its time for me to shop for new tyres. Been looking at Crossclimates today and although Agilis are meant for vans you can't buy them in 235/55 R17. Shame really as the suggested extra durability is appealing. So if I go for these its a toss-up between SUV and +. Probably the latter for my 2WD Beach.
If you go up by 5% sidewall to a 235/60/17 Crossclimate SUV they come in a 106 load rating.Yep, it's complex. The Agilis is available for the 215x60 size fitted to some Cali's. They have a very high load rating (107/109) and have a very different pattern to the SUV and the + models.
That's the interesting part....they have (to the eye) exactly the same pattern, and the same load rating (which I think is as close to get to measuring the strength of the side walls). I'm VERY happy with mine, just confused!Get the SUV version as more suited to the weight of a cali.
SUV has stronger sidewalls and tread is designed to clear out grit, stones and mud better than 'passenger' version.
