Gazellio
It if it the awning I should be able to make it rattle a bit by tapping it but nothing.
I think it´s the rear scissor hinge in the roof.Re above it did not remove the rattle it was evidently not the awning rattling. It appears to be definitely coming from the sliding door even with the removable table removed....![]()
I had the rattle though I don't have an awning. Experimented with sliding door, it's window, seat belt mounting, etc.Re above it did not remove the rattle it was evidently not the awning rattling. It appears to be definitely coming from the sliding door even with the removable table removed....![]()
Next thing on the list :I think it´s the rear scissor hinge in the roof.
Finally pulled down the door blind a couple of inches and rattle was silenced. After a few tries up and down with the blind it was clear that it was the cause of the rattle.
Now blind is fully up and rattle has not returned.
I've also cracked the front end cap through not standing in theI took mine off today too. Looking forward to a quiet winter!
Hopefully I'll manage to refit it without dropping and smashing the end cap this time!
Try a little silicone lubricant that plumbers use and it will glide on! Any little residue won’t harm the make-up of the rubber compound which washing-up liquid might do.Also, I read some people had trouble putting back the rubber strip, having to use washing up liquid. In my case it went back on easily.
