I don’t ….. I put some cold in the bowl then add the boiled water, just to play safeIf I boil pasta is it ok to poor boiling water down the sink. I was worried about the plastic pipes.
Thanks in advance
Andrew.
We have always poured the boiling water from pasta pan through a make shift colander down the sink and so far it doesn't seem to have caused us any problem. You do get a wierd pop sometimes where the sink aluminium expands quickly (you get this in a house aluminium sink too sometimes too though) but all seems fine.If I boil pasta is it ok to poor boiling water down the sink. I was worried about the plastic pipes.
Thanks in advance
Andrew.
Non issue, any water hotter than 100 C is steam and the melting point of even poor quality PVC is 160 C upwards.If I boil pasta is it ok to poor boiling water down the sink. I was worried about the plastic pipes.
Thanks in advance
Andrew.
Only wish they’d put some design thought into the use of materials for the corroding roof!Our pipe gets blocked when kids spit toothpaste down there (now banned).
I use drain cleaner and boiling water straight from the kettle to clear. It’s plumbing plastic. Same as your home kitchen sink u-bend. It’s a VW product. That’s why it costs £80k, materials and most importantly design thought.
That roof of yours won’t corrode nowOnly wish they’d put some design thought into the use of materials for the corroding roof!
