I am at present trying to find a way of running an iPod dock off a 12v supply which should work. Just have to make sure the polarity is correct. Maplins have some very handy ready made leads. VW aren't able to remove the auto cut off on the cab radio, but did agree that it was a bit silly to have a stereo that you couldn't fully use with the vehicle stationary. They said that if it was recoded it would constantly come up as a fault each time it was checked. 2 weeks and 3½ days now.
I know it seems silly that the stereo cuts off after 30 mins. But if you have the RNS 510 SatNav then the unit is more like a mini computer than just a radio and the whole unit boots up when switched on and uses some power which comes from the Engine Starter battery which can soon get flattened. You could get it wired to the Leisure batteries but it would still switch off after 30 mins as that is a CanBus function. Most people use a standalone music player of some sort run off 12V.
