Borris
Our first Cali had laminated glass and to start with it was a little tricky to get the windows to close properly when the Dubflectas were first fitted. I had the other type though, not the "skeeks". However I doubt if it makes any difference which type you have when fitting. Laminated glass is thicker so the window will automatically open if it discovers an obstruction when closing. That's how it's designed to operate. To get over this, once you have fitted the Dubflectas strictly as per the instructions, you have to assist the window to close fully. (Have a look on Youtube. There is a useful video on fitting Dubflectas).With the door open, activate the window close button then quickly assist the window up into the fully closed position with your palms placed firmly on both faces of the glass. Once fully closed leave it closed for several days before trying to open it again. In that time things should relax and you shouldn't have any more issues.Sorry to resurrect an old thread, @Borris, but I've recently been wrestling with fitting Dubflecta Sleeks and their failure to comply led me to discover that we have laminated glass in the front of the van! Even just placing a clip on top of the glass I can't get it to fit all the way on (glass is too thick), and the window is definitely not shutting with three or four clips in place. It's actually even fouling on the Dubflecta itself. I've emailed the manufacturer but had no reply. Any guidance gratefully received if you did go down this route.
Good luck.
