![Skewif](/data/avatars/m/9/9863.jpg?1537937986)
Skewif
It’s not what you have, it's where you wake up.
Only the rear bush is different. T32 part number 7H0407182. 7H0407182A is the T28/30 bush. If you give VW your reg or Vin No they will say it doesn't fit your vehicle but it does and well worth doing while suspension apart for any reason.I hate to drag up an old thread. Though admittedly, I'm not sure why it matters...
Anyway, looking to order the T32 control arm bushes and can see how it may be difficult to get the correct ones. Do you have the part numbers for the correct ones you received @Skewif? I think I need Looking here, it seems that there is only one PN for the forward bush and several for the rear bush (fwd control arm). Is it only the rear bushes that need to be changed for solid ones?
