GordonH
The interior layout of the Knaus is quite different from the GC600 so it could be the habitation wiring loom is different. An easy check to see if you have the same wiring to the solar panel area that is present on all GC600s even when no factory solar is fitted is to pull the headlining slightly away from the front skylight and look forward between the trim and roof GFRP. If the wiring is there you will see it stuck to the roof in the middle of the raised section over the cab.Also watching with interest. I have the Knaus 600XL and the dealer fitted me a 120w fixed solar panel to a 90aH LiFePO4 battery but lacking a little on solar power and considering overlaying the SP104 over the graphics. Keen to know where the cable comes into the roof space though?
