ThomasHJ
Hi Carter, perhaps it helps if you describe your specific problem in more detail. As it may differ from that of others. Maybe some questions will help other to help you. For example:
Has the remote previously worked or did you recently acquire the cali second hand and don't know? (perhaps it's not paired with the heater)
Does your heater work when you operate it from the control panel directly without using the remote?
What flashing of lights do you see? Green or red?
Does the heater light on the control panel come on when you turn the heater on on the control panel?
Is there enough diesel in the fuel tank?
Have you tried resetting the control panel and tried again afterwards?
