Looks like a very generous 2m!This was in France and I didn't measure it.
It does indeed.Looks like a very generous 2m!
Most parking spots at the coast of France near the Dune du Pilat advertise a max height of 1,80 at the gates but that’s poppycock. Instead of changing the gates the just changed the signed .
I’m 1,96m and just quickly walk up to the gate with my fist on my head to check.
Conversion I presume as you get a warning on the SE/Ocean.I think I would be forever opening my window to take a peek before driving through!
A friend of mine from Wales stopped for a picnic, forgot to pop her pop top back down, drove out of the car park sheering it off - vehicle was not even 3 months old!!
I wonder, do you get a warning on the Beach or Coast with a manual roof?
My week 43 build 4motion will be lowered by the dealer before I get it 30mm is 30mm easier in carparks !This is interesting - I measured the loan Cali we have (with awning) yesterday and it was 1.99m to the top of the awning at the rear. I thought with an awning they were over 2m?
I was specifically considering lowering ours to get it to be under 2m so it could go in car parks easier.
Bath Newbridge Park and Ride has a 6ft 6 inch height barrier in and out. One inch space coming in due to rising road but 3inch space out. Wife insists that wind out awning is the highest point (sic). It isn’t because I’ve measured.Entered this carpark in the Mendips in the dark, it was rather tight with a brief rub on the awning. Getting out was easier in the daylight!
View attachment 67782View attachment 67781
We’re off to the Mendips in June. Where was this car park @Brian’s Dad? I’ll give it a miss!Entered this carpark in the Mendips in the dark, it was rather tight with a brief rub on the awning. Getting out was easier in the daylight!
see Wood and Smitham Chimney - it's a good spot once you've squeezed inWe’re off to the Mendips in June. Where was this car park @Brian’s Dad? I’ll give it a miss!
This is why I crawl under the barrier at the recycling centre, even after countless visits. One day, either the road will rise or the huge barrier will settle!I’ve often wondered what happens when the car park is resurfaced. I guess you have hope that the original dimensions included a little bit of redundancy.
In the UK you don’t need to worry if it’s a council funded carpark, as it will never get resurfaced.I’ve often wondered what happens when the car park is resurfaced. I guess you have hope that the original dimensions included a little bit of redundancy.
Sometimes the headroom changes while you’re parked...In the UK you don’t need to worry if it’s a council funded carpark, as it will never get resurfaced.
That is so bizarre.Sometimes the headroom changes while you’re parked...
Cars crushed at Crayford flats after water pipe bursts
Cars are crushed after a burst water pipe floods an underground car park.www.bbc.co.uk
