Help. Touring in Ireland and the Europlug has a problem
Chenti
Hello Everyone
Hope you are all enjoying this fabulous weather in the UK ...and Ireland. Which is where I am now
I have a annoying problem in that the 2 pin euro plug socket that is behind the passenger seat and on the B pillar has popped off the facia panel and gone behind so I cant get my fingers to it
Has anyone removed the square facial panel before?
I hope its not a big job as I'm a few weeks from returning the the UK and would rather like the use of this socket on the trip.
I can still use the UK 3 pin each evening through when off EHU the euro socket is really useful.
I've emailed the UK dealer and hope their tech team can advise ...though I suspect they will say fine a VW dealer to look at it which is a pain if that the only way.
Anyone had this happen before?
TIA
Vince
If you search your issue on the forum you will find out it happens before with others , been posted sevral times before. if you can't reach for it you need to remove some trim and put it back in .
As said by HC I fixed mine following advise from other members post on forum.
Ours pushed back into the socket. Forced off a cover and after fix replaced with screws.
Temp fix put in place and I’m now charging devices again
Thanks for the comments and pointers
Vince
