Nice VW you've got there! And thank you so much for all that great information!
OK, first, I have the van finally! It has these plaques in it showing it was fitted out by Westfalia-Werke.
I do not have a service booklet for it, and I have no idea where the fuse box is (to check it it says "CALIFORNIA COACHKR").
On the seat, I can hereby attest that it is not as heavy as I feared. I was able to remove it solo flip it around, install it backwards, take it out again, and then install it in its original orientation. I had to kind of angle it off my hip, but at no point did I feel it was tremendously heavy. (Note: I am a weak and feeble man, spending most of my time at my desk, typing on this thread, apparently
Oh, and on the seat, I would say that it can definitely be safely reversed. It clicks in backwards quite solidly. However, the leg room is only deep enough for one set of legs. So I am going to nix my plans for facing seats, unless I can figure a way to safely extend the rail (extreme doubts there and will likely not try).
One other question...draining the wastewater. This van does not have a lever to drop it through the floor but appears to only have a port on the side (near the rear bumper) to maybe suck it out? Does that sound right? Am I missing something? I'd like to be able to drain it without needing special equipment...
THANK YOU!
