Perfectos
posted to assist other and make as many people aware of this issue as possible.
below are photos of a Brand new seal fitted following the second failure of a roof seal. This seal was fitted two weeks ago !
you can clearly see the rust on the tape (tape applied by the dealer, at my request following a failure of the previous seal along the front edge) fortunately the rust has wiped off and the dealer had been informed of the failure Of the new part !
This is an absolute disgrace by VW, this is a new part supplied to the dealer and is a replacement (again) for a failed roof seal.
note Two of the failures have been on the front roof section where no factory tape is applied ! which if left would lead to roof corrosion a costly repair and a very long wait to have the repair carried out .
during my conversation with the dealer today, they suggested that I dont take the new seal off as it needs to seal !
I pointed out that I could see the seal had failed, rust was visible outside & when the seal was removed it was Blatant.
Go check your roof seals and get them replaced if you see anything like rust.
