Water must be getting in somewhere around the tailgate, thatOpened the tailgate up and found this this morning. Looks like condensation. Interesting as none was on the window. The RH of the van was 45 all night due to dehumidifier and heat, plus windows open under wind defectors both sides. But it seems to make no difference at the back. Putting my hand down under the mattress at the back, it’s cold. So all the methods to stop condensation in the front cabin, don’t work down there. I suppose it’s worth trying a tailgate lock to get ventilation into that area ? Bit nippy maybe at this time of year. If it’s so cold down their that it creates so much condensation, I’m surprised this is not happening more often in oceans. But tailgate lock and ventilation their should help
When I say tailgate lock, I mean the Brandrup airsafe ..
I think I have found what might be causing the issue. When I had the blind replaced the dealer has not put back the trim properly. There is a big gap around the trim. This is where all the water seems to be at its greatest. The fact it’s not flush anymore let’s lots of air form the cabin onto a direct cold surface.
In addition inside the chair storage there seems to be a whole load of the black foam missing at the top. All this allows even more warm air to get behind the trim.
For my upcoming dealings with the dealer, would anyone be able to take a picture of the trim in place flush and a more importantly a picture inside the chair storage, showing the foam at the top, just so I can see what’s missing. That would be amazing if anyone has the time
Also what do you think my position is with the dealer, as they fitted it incorrectly, and that caused the issue. I want them to replace the foam and replace everything that got mouldy, and put back the whole door trim set exactly how it was before they messed it up. Not sure they have the skill to do this as they seemed to have made the decision to leave bits out and still not got it to fit .. whole new tailgate if they can’t put it back to normal ? How much should I push for ?
I think you need to pop back to dealer, sorry to say.Re-opening this thread as I now have a leaking tail gate. Only noticed after heavy rain/sleet/hail the last couple of days. There are droplets on the panel above the rear window when I open the tailgate. And again at the end of the panel where the material section for the camping chairs starts.
Not impressed.
That is my plan. But was hoping for more inside info from the forum before I go. It has saved me thousands in the past...I think you need to pop back to dealer, sorry to say.
Yep me too.That is my plan. But was hoping for more inside info from the forum before I go. It has saved me thousands in the past...
Yep me too.
I only said that as it’s a brand new van and i think a lot of this post was condensation problems like I use to get, and solved with extra insulation on tailgate (only single glazed).
I leave rubber bung out too, hope you get them problems ironed out so you can enjoy the new van (dreaded teething problems!)
The new beach camper looks a cracking van
I feel stupid for not taking pics when i first noticed yesterday and then again today. When you’re busy away training dogs or off for a walk, you forget to ‘prioritise’ this as the dogs take over your priorities...Yep me too.
The new beach camper looks a cracking van![]()
Just checking did you have wet dogs in van and then notice it, as Zebedee being wet and my waterproofs can cause a lot of condensation.I feel stupid for not taking pics when i first noticed yesterday and then again today. When you’re busy away training dogs or off for a walk, you forget to ‘prioritise’ this as the dogs take over your priorities...
No. And an excellent question. But as I don’t yet have my new dog crates. The van has barely been driven and not with dogs, or even less so, wet dogs.Just checking did you have wet dogs in van and then notice it, as Zebedee being wet and my waterproofs can cause a lot of condensation.
This is different to my leak. It is definitely from the top of the tail gate and then dripping down... maybe I need to start a new thread when I get photo’s so as not to misdirect yours.So to feed back what happened in the end. The dealer did rain tests and found that the tailgate was leaking where the wiper is. This is why water was coming out of the bung at the bottom, then pooling below the fabric. Not helped by the trim not fitted correctly (condensation)
When they looked for leaks the first time they missed it. The second time the set up a rain simulation (hosepipe)for a few hours to find the leak. So a quick leak test a dealer might do might not find it, it needs a longer simulation.
I really hope you find the sources the leak. Oh and the trim they put back has opted off again last weekend. Back to the dealer again
If it is from Above the rear window, I would look at the rubber seal at the top of the tailgate opening.This is different to my leak. It is definitely from the top of the tail gate and then dripping down... maybe I need to start a new thread when I get photo’s so as not to misdirect yours.
It’s a few weeks old and tailgate barely been opened. I’ve not been using it as awaiting new dog crates.If it is from Above the rear window, I would look at the rubber seal at the top of the tailgate opening.
Is there anything in the space behind the seal, such as leaves etc:. Clean it.
Is the seal deformed? If so it needs replacing.
Pull the seal off slightly so it stands a bit prouder and pushes against the closed tailgate.
I’ve seen it mentioned elsewhere that the tailgate seal can be pushed on too far and doesn’t actively seal against a closed tailgate. Severe, and I do mean severe rain, dependant on the direction and wind can then overcome the seal.It’s a few weeks old and tailgate barely been opened. I’ve not been using it as awaiting new dog crates.
I’ll try and get some pics next time it rains (won’t be long in Scotland...?
I agree with Welshgas on a possible area of a leak. Had the same on my new T6 when away camping with a wind coming off the sea with the rear of the van facing into the wind. Has drips of water appearing on the trim above the rear window and dripping onto the bed. Read his post at the time and gently pulled the seal away from the body slightly around the top area so as to give a tighter seal against the top of the closed tailgate and this certainly fixed the issue for me, never had any leaks since.I’ve seen it mentioned elsewhere that the tailgate seal can be pushed on too far and doesn’t actively seal against a closed tailgate. Severe, and I do mean severe rain, dependant on the direction and wind can then overcome the seal.
The trick then is to just ease the seal up along the top, and then just shut the tailgate so you get a positive seal. Rarely recurs.
