Digger
Are Kingston Campers still trading?Looks like the HORIZON is the one
Not under that name:Are Kingston Campers still trading?
I am interested in sourcing an additional bench seat for my Ocean, mind you i would hope it would weigh somewhat less than 75 kg.Hi Adam
All I know is that it is best to pre-fit the seat clamps in the two rails. We asked the dealer to register it as a 6-seater in case we wanted to add a bench seat and when we came to pick it up they'd fitted these seat brackets for us. We were given a weird device to slide them along the rails so as not to interfere with the rear seat's forward travel. We were also told the bench seat can be placed looking forward or back and as I said above, that the bed still opens... The downside is that it weighs around 75kg I believe.
Martin
Unfortunately the ones on offer are either the double passenger seat off a van, a version of the California rear seat/bed already fitted in the van (much to heavy to lift in or out) or of a type that use the floor fixings present in kombi/shuttles etc.two on eBay
To be fair, I hope that VW use the opportunity of some healthy competition in what has been a monopoly, to improve and not rely purely on that monopoly position and the "brand" alone.
I just need a simple/light none adjustable double seat with built in belts and if possible isofix points to take my son, daughter-in-law and two babies out in one car. It also must fit in the existing seat guide rails.
I understand it is a big ask but as Mercedes have shown above there must be a market for such a seat.
Except in the UK where it isn't an option... only adding the single seats areUnfortunately the ones on offer are either the double passenger seat off a van, a version of the California rear seat/bed already fitted in the van (much to heavy to lift in or out) or of a type that use the floor fixings present in kombi/shuttles etc.
Hi Adam
Martin
We're going to have the air heater fitted this autumn (about half the price of having it factory fitted, same model). The water heater doesn't seem to be recommended on the Spanish forums at least.
Something else to be aware of is that there are two air conditioning systems to choose from, Tempmatic and Thermotronic. Only the latter provides true AC at the rear. We have the Tempmatic and slightly regretted it yesterday in temps of approaching 40C.
Martin
The " Water Heater " if I am correct is for heating the Engine Coolant. It is automatic, starts with the engine if ambient temperature is below 5c and runs until engine temperature is about 80c. Helps with warming up the engine quickly so the internal heating system is active sooner. It does use a lot of electrical power so that is why it runs with the engine. You can modify it to heat the vehicle without the engine BUT it will still heat the engine coolant, consume a lot of battery power and you have to have the Climatronic AirCon system for it to be able to heat inside. Using it for too long will flatten the Engine Battery.We're going to have the air heater fitted this autumn (about half the price of having it factory fitted, same model). The water heater doesn't seem to be recommended on the Spanish forums at least.
Something else to be aware of is that there are two air conditioning systems to choose from, Tempmatic and Thermotronic. Only the latter provides true AC at the rear. We have the Tempmatic and slightly regretted it yesterday in temps of approaching 40C. There is an air circulation mechanism at the rear which has an intake at the back (lower left, near where the gas bottle is stored) and pushes out air under the fridge, but this isn't cooled (it is more for warming up the back in cold weather). The solution is to push the rear seats forward where they benefit from the cooled air which is emitted from a large vent in the slightly raised space between the front seats.
Another data point from yesterday: we managed 7.2 l/100km, just over 39 mpg, on a long (~900km) motorway journey at a more or less constant 120 km/h (~75 mph) fully loaded, using the eco setting and cruise control. I remember the days when 40 mpg was a good rate for a car so it is impressive that nearly 2.5 tonnes can be shifted from one end of Spain to the other on a full tank of diesel.
More impressions: the cruise control will take some getting use to as it is on a stick just below the indicator stick, and the default action of pushing it upwards is to add 10km/h, not necessarily what you want to do when indicating right...; the whole Audio 20 USB system (which in spite of the name is not just for audio) seems over-complicated to use (a triumph of style over substance). I'm coming from an 11 year old Renault Scenic and it was a lot simpler to accomplish the same tasks. I'm finding the 360 degree camera invaluable for getting into tight parking spaces between concrete pillars that wouldn't show up with just the rear camera. We have a lot of underground parkings over here and the MP fits into them and also has a much tighter turning circle than a car which helps a lot. I guess the same is true of the T5/6.
Martin
The " Air Heater " heats the inside of the vehicle and is independent of the engine or ignition and can be used whilst parked or even when driving. It uses the Leisure Battery.
This is all really helpful thank you! Can I ask where you are getting the air heater fitted? Does it all get integrated with the existing controls and ducting? Its a £2.5k option here so happy to hear about it being cheaper!!
The UK base spec is actually very high, so we get thermatic as standard, but the options are limited really!
