Sorry,Is it the cable flap you want painting or is there something in the picture I can't see on my phone?
Sorry,
Yes the hookup flap. Always thought it was a feature when it didn't need to be.
Sorry,
That's my thought at the moment.Trouble is that if the paint starts to peel it will look crap, yes, yes know if it's done properly it won't, the chances are it will.
I would personally leave it alone
Don't do it. Not worth the risk. Could look tacky.That's my thought at the moment.
If it did go wrong that wouldn't be covered by warranty. Hmmm. Just a little tempting that's all!
I think it is a risk. But as it's a VW body shop I'm not sure it would look tacky. The worry is it could flake/chip over time. I'll probably err on the side of safety (despite my name).Don't do it. Not worth the risk. Could look tacky.
Sent from my iPhone using Tapatalk Pro
It does seem a pity that they don't treat the cover the same way as they might a fuel filling cover - I suppose there must be a reason, but at the moment I cannot think what the reason might be.
After a bit of use, it's a mild distraction to see it in the passenger side mirror, flapping away......It does seem a pity that they don't treat the cover the same way as they might a fuel filling cover - I suppose there must be a reason, but at the moment I cannot think what the reason might be.
Probably something to do with Mains Electricity and a metal car. Keep the two apart at all times.It does seem a pity that they don't treat the cover the same way as they might a fuel filling cover - I suppose there must be a reason, but at the moment I cannot think what the reason might be.
Nooooo.....it's just one of those things...after so much use, in fact a little use as I have very rarely been on hook up...the latch clip gives up and it falls away...other vehicles likely think your fuel cap is undone !Probably something to do with Mains Electricity and a metal car. Keep the two apart at all times.
Lol, lets not get in a flap about it....
If this is the part, or similar to the part, used on the T6, I cannot see any additional danger by having a flush fitting with a metal flap. Most household back boxes are metal, I have brushed steel sockets and light switches in my house. I suppose a key difference is that if the flap somehow becomes live, so does the entire vehicle.
Shocking!
Probably on account of it being done post production to the vehicle that trundles down the production line. It was not part of the original design. So cut a hole and stick a plastic thingy in is the solution.It does seem a pity that they don't treat the cover the same way as they might a fuel filling cover - I suppose there must be a reason, but at the moment I cannot think what the reason might be.
Same on caravans which are designed from scratch so maybe there is something about using such a part.Probably on account of it being done post production to the vehicle that trundles down the production line. It was not part of the original design. So cut a hole and stick a plastic thingy in is the solution.
Mike
I think the reason is likely that it would flake, chip and peel with a little time and then look a bit scruffy.It does seem a pity that they don't treat the cover the same way as they might a fuel filling cover - I suppose there must be a reason, but at the moment I cannot think what the reason might be.
They're going to be spraying the whole side (I imagine up to the crease half way up).Looking at the damaged area you'll need to wait till you receive the estimate and then have a word with the bodyshop as regards the repairs. Fitting a complete panel is more work,some insurance assessors may opt for filler etc. As your california is reasonably new the paintwork might be able to be blended in, all depends how good the sprayer is and the paint. At the end of the day if you are not happy about the method voice your opinions.
Yeah, Aviva (Comfort insurance) didn't have a specific body shop to use. I think it's because they see the Cali as a specialist vehicle. So I just went to my dealer and asked them who to use.Did you get a VW approved repair shop.
Your probably right. I think I'm going to leave it and not meddle.Sorry to see picture of your dented Cali. Annoying!! Glad no one was hurt.
About painting plastics - it seems to me that this is perfectly possible without risk. For example the back of wing mirrors are plastic as are bumpers etc. If the flap is "ABS" (that is a plastic type) then the paint shop should be able prepare the item for spraying.
That said, if you do go ahead and have it painted would that not draw attention to the fact that the panel has been sprayed as well which will then prompt the question why? Do you want to draw attention? Just a thought.
